Engine rebuild on 1939 U/S AR
Tracy Redd
04-13-2004 21:53:21
I took a head, crankshaft, block, rods and pistion. All it's need to get crank reground, repair and hone block, bore out the rods and insert rods bearing, wrist pins, new main bearings, and head work. I took it to machine shop in Kentucky last week. I ask that guy how much it gonna be ( two times on different people)? He said it should be around $450 to $500. They hasn't started work on it yet. Today, Machine shop call me and tell me it cost me $500 to machine work plus $400 for a labor and deposit $500. Last week i took all the stuff to machine shop and they did not tellme about labor and deposit. I told them to forget it!! i have drove 3 hours to get there to drop the engine off without telling me about labor and deposit. I have to back to pick it up anf find another honest place
Can machine shop bore out the rod bearing and insert bearing instead of babbit bearing? what about the Main bearing? What will machine shop do on main bearing? Is there any good Machine Shop in TN, KY or AL.
Thanks
Tracy
Mike M
04-14-2004 03:58:48
 Re: Engine rebuild on 1939 U/S AR in reply to Tracy Redd, 04-13-2004 21:53:21
I had a set of late B rods converted to inserts. The machine shop had done these before they suggested it.It was cheaper than rebabbiting they did have to use one of the thick spacers out of the shim pack to space out the rod. Have you checked with JD on those main bearings?
also check NAPA or other aftermarket. If you can find undersized bearings you grind it down if you can only find standard size it will have to be built up then ground to standard size.
