3020 frame rails cracked
Jason (MA)
01-25-2004 14:10:42
I just bought a 3020D that someone cracked the frame rails and welded in a patch piece. I see new rails forsale at a couple of different places. Is this a common problem?
JDTECH
01-25-2004 14:34:01
 Re: 3020 frame rails cracked in reply to Jason (MA), 01-25-2004 14:10:42
The biggest problem I have seen is when the side frame bolts work loose and are not retightened. Also if someone has put a loader on it and not install the stiffener plate that goes between the loader mounts under the oil pan, the side frames tend to flex and possibaly crack.
Stuart
01-26-2004 08:00:06
 Re: Re: 3020 frame rails cracked in reply to JDTECH, 01-25-2004 14:34:01
I Know some one who has 3010 with a loader on it. The loader is a model 48. Do I need the stiffener plates for this type of setup or I am safe to use it as is. thanks for the help
JDTECH
01-26-2004 20:10:16
 Re: Re: Re: 3020 frame rails cracked in reply to Stuart , 01-26-2004 08:00:06
There are a lot of loaders on tractors out there that do not have any support underneath and get by only for extreme light use condidtions. My opinion is the added insurance of the extra support is well worth the investment compared to the damage it could cause down the road.
