630 won't start UPDATE
MIKE HANLEY
01-25-2004 14:00:56
Well I did freeze four fingers off!!!!! Started with "by the book" timeing. Lined up thr TDC mark on the flywheel. Layed no 1 spark plug on the madifold and turned the dist. NO SPARK. Can't time if there is no spark. Layed both plugs on the manifold and rolled it over. GOOD SPARK. Went back to try the timing again,,,,NO SPARK. Put both spark plugs back in and while rolling it over turn the diat back and forth to try and get a pop. NOTHING. Gave up before my index finger froze off. Will need that tommarrow when I dial the dealer on the phone.
Just got off PERTRONIX's web site. Trouble shooting page has some items to check if the engine won't start when installing, but nothing to trouble shoot when it won't start AFTER installation and AFTER it has been running good for a week.
On spark plug gap it says "The Ignitor has no set specifications in which the spark plugs should be gaped at. Every engine responds differently to spark plug setting. In most cases increasing the factory recommmended by .005 improves the engine preformance.
Under spark plug wires it says, "Flame-Thrower spark plugs wires are the perfect compnions to our other performance products." But in the catalog part they are listed for 4, 6, and 8 cylinder engines by model and make.
Yes the JD 12 to 6 volt resistor under the dash has been by passed.
PS: The snow did come enought to make the ground white, but the grass stubble is still higher then the snow. cattle and horse came down for water. It's 14 degrees on our thermontor. Though, what the heck. Walked over to the WF 730D and it poped off on the first roll around. Didn't have it pluged. Not enough snow to waste fuel plowing, but I did take out 4 round bales for the cattle and the horses.
fixerupper
01-25-2004 15:53:06
 Re: 630 won't start UPDATE in reply to MIKE HANLEY, 01-25-2004 14:00:56
You say you have a resistor under the dash? My 630, which is a late one, my dad took delivery of it new in Nov. 1960 after deciding not do buy one of those new 3010's, does not have the ceramic resistor but instead has a coil with a resistor in it, they call it a 6 volt coil I think. I know it came new that way. This tractor also has a Wico distributor instead of a Delco. Did Deere pull a switch in the middle of production? Do any of you Deere guys know anything about this? I have thought about electronic ignition but it has always started and run very well with minimum maintenance. I don't believe I can get electronic for a Wico anyway. Wish I could help you with your 630
since I have lots of experience with one, but electronic ignition is out of my league.
Clooney
01-25-2004 15:36:13
Mike, your statement..."Lined up the TDC mark on the flywheel. Laid no. 1 spark plug on the manifold and turned the dist. NO SPARK" ... Says you either have an internal distributor or E.I. problem OR, you were on TDC EXHAUST & not COMPRESSION.. Those 630's only spark every other revolution so if you were on exhaust I wouldn't expect a spark when rotating the distributor [maybe that was your problem]..
~If you were on L/H compression & still didn't get a spark then I agree with Bob's observation & that's you might have a large reluctor to pickup air gap.. Did you try to wobble the mag shaft around to see if the distributor bushings are loose?
~Did you use a voltmeter or test light & check for 12 volts at the coil? Maybe there is a poor connection in one of the wires.. If the starter cranks then that pretty well says that the ign switch is working & making contact to supply power to the coil circuit..
~It sounds like you are going to let the installing dealer handle the problem. Let us know what they find [if they tell you the truth, a lot of times they won't if they did something wrong]...
[email protected]
MIKE HANLEY
01-25-2004 21:57:48
 Re: Re: 630 won't start UPDATE in reply to Clooney , 01-25-2004 15:36:13
When I was rollig it ovet to find the comprestion stroke, I stuck the tip my finger into the hole and it would suck it in on the intake and blow it out with the exaust. The tip of my finger was wet with gas. When I rolled it over without the plugs, you could see a mist of gas coming out both spark plugs holes. When I rolled it over with the plugs in they was VERY LITTE smoke. When I pulled the plugs the plugs were wet to the point that you could see the shine of the gas but not what I would call overly wet. Everything appeared tite, but there is a post below that may lead to the problem. The gap between the unit and the magnet is way more then the .010 that is explained in that post. As to the dealer I would trust my life with Ray. (The two cylinder mech.) I have learned over the years what my limits are and what my limited out door shop can accoumplish. Ray overhauled the 430 crawler, and did all the work on the steering cluchs, and the track work. He's the one that overhauled the 730D. When ever they was a question or he found something out of the ordinary, he was right on the phone to me and would wait till I went down there and we looked it over together. In this day in age Ray is a rare find. (And I'm not just saying that becausce one of the service managers and a couple of the mech's also read this site.)
John T
01-25-2004 14:42:44
Mike, just how cold was it????? ??
1) First, on that elec ignition, versus distributor rotation which still opens a set of mechanical points regardless how slow, it may be possible a too slow rotation of the distributor wont fire the coil at all, cuz the pickup coil dont get a sufficient voltage pulse to trigger the soild state. Therefore, that leaves Ol Mike with a timing light down at the flywheel, while the first wife or the lil woman or the young or old lady cranks the starter a bit to check its initial base timing. Did you try that??? With it on the left plug wire and a light on the flywheel, if in time it should flash near the mark.
2) Was there any procedure for settign the air gap between the magnet ring on the shaft to the base mounted pickup coil????? Still, it sounds like the spark is plenty hot, maybe not at the correct time???
3) If the ring on the distributor shaft aint moved and the unit has a good ground to the base plate and she sparks the way you describe, I dont see how the timing could have got so far off all a sudden myself????? ?
4) I would still try fresh plugs, maybe Autolite 388 gapped to 0.045 or so.
5) Can I assume theres good clean fresh water free gas in the carb???? Is there any vapor coming out the stack??? Is the choke actually working????? Maybe the rod is being pulled, but the butterfly plates isnt getting closed????? ? (I have a 620 that did that and it wouldnt start with a stick of dynamite) Have you removed the air pipe or checked the air cleaner bowl???
The plug wires may again be shortign/arcing due to higher operating voltages, check that out. As we posted earlier, they may need to be resisitive due to the coil, but I dont think thats your immediate problem. I guess the coil is designed for a full 12 volts, no external ballast required, many those hot coils are straight 12 volt units???
Actually, Im suspecting more of a carb or water or non working choke or fouled plugs now instead of shes out of time so bad????? ?????
Send the wife out once more to charge the battery, check the gas and especially the choke is actually closing (That can happen), install fresh plugs, look at the timing while cranking with a timing light, and if she still dont start, Clooney will come fix it.
Let us know Mike
John T
MIKE HANLEY
01-25-2004 21:25:15
 Re: Re: 630 won't start UPDATE in reply to John T, 01-25-2004 14:42:44
Can't sent the wife out. She's finishing posting the year end books. THAT DAY arrived last week. Meaning the last paper work arrived in the mail to do the taxes. Rigth now she could care less that only one of the tractors won't start. The taxes are her priority and thje Tax book and the record books will be on my desk and the wife on my case till I get it done.
YES I SAID 14 DEGREES
Bob
01-25-2004 15:02:31
John T,
One of the selling points of the Pertronics (pertronix?) units is that they use a Hall Effect magnetic pickup, and will trigger any time the magnet passes the sensor, even SLOWLY.
Your point about the gap between the trigger and the Hall Effect unit is a very valid one. I meant to mention that in my previous post. Pertronics supplies a little piece of plastic feeler gauge in the kit. (0.010?) However, the closer the better, as long as the magnet wheel and the Hall Effect unit do not rub on each other due to wobble in the distributor shaft, or play in the shaft bushings.
The unit can be tested by pulling off the magnet wheel from over the cam, and stroking any ordinary magnet past the Pertronics unit, as close as possible to the sensitive Hall Effect area that that magent wheel passes by. With the ignition switch on, each pass should fire the coil and produce a spark.
MIKE HANLEY
01-25-2004 21:30:36
 Re: Re: Re: 630 won't start UPDATE in reply to Bob, 01-25-2004 15:02:31
BINGO!!!! You may have sometrhing there. The gap is MUCH grater then .010
John T
01-25-2004 20:14:55
Thanks Bob, I knew from auto type elec ignitions Ive worked on that gap has to be close, but not touch of course. It still looks like a veryyyyy y slowwwww pass by of a magnet (even with hall effect) wouldnt make a very strong pulse of voltage in the pickup coil to trigger the switch, but I guess even a slow hand movement of the distributor suffices from what you say.
Im not convinced he even has a timing or a elec problem yet, maybe a fuel or choke or partly fouled plugs.
Fun thread, thanks for the info Bob.
John T
Bob
01-25-2004 20:57:27
 Re: Re: Re: Re: 630 won't start UPDATE in reply to John T, 01-25-2004 20:14:55
A Hall-Effect switch is a solid-state switch that switches states (high to low, or low to high) at a certain level of magnetic field. The rate at which the field changes is not very critical.
Bob
01-25-2004 14:33:24
In your earlier post, you said it wouldn't start, but HAD spark. What has happened since then? If the engine had been running with the proper timing, there should be no reason for timing to be off because of the Pertronics unit.
Get an ANALOG voltmeter. Should have 12 volts to ignition switch side of coil. Distributor side of coil will have a fraction of a volt. When distributor turns, and magnets pass the Pertronix unit, voltage at distributor side of coil should alternate between 12 Volts, and a fraction of a Volt.
If voltage on distributor side of coil remains low while distributor turns, module is probably shorted out. If distributor is rotated, and voltage remains continously high, module is probably open.
Depending on the primary resistance of the coil, I don't think it is always wise, nor do I believe Pertronics recomends removal of the ballast resistor in all cases. The original Pertronics unit remains in the "points closed" mode when the engine is not turning, and the resulting current is dissipated between the coil and the Pertronics unit.
That being said, the Pertronics units work very well, and seldom fail. If it has failed, I believe the combination of no ballast resistor, and the possiblity the switch could have be left on without the engine running would be suspect.
Was the tractor converted to 12 Volt negative ground, or was a 12 Volt positive ground Pertronics unit used?
If the batteries became run down, and were charged or boosted in the opposite polarity of what the electronic unit was designed for, it may have been "toasted".
