Hello all...it's been awhile :( Sorry for the delay, I've been really busy with college here toward the end of the semester. I have the 520 LP running and moving. After fixing a few minor leaks and stuff like that I decided to try and get started on seating in those rings. I tied a large piece of concrete from an old barn foundation and drug it around in the feed area of the pasture. This proved to be a decent pull for it. I tried in 3, 2, and 1st gear. After messing with the adjustment on the governor arm and the rod that goes to the carb from the gov. arm, I think I found a happy medium. Not too responsive to the point that it's jumpy but not too sluggish.Well anyway, there I was lugging away in 3rd, and it began to be too much for it as the dirt piled up in front of the concrete "chunk". So I then went to 2nd, which it seemed fine at first. My issue is that after a minute or so it will just lug down (like the choke would be pulled out on a gasoline tractor) and will die unless you pull the clutch out before 800rpm or so. If not it will just kinda back fire/sputter and die. The wierd thing is that it starts up right quickly and then the same again. I tried changing from liquid to vapor on the convertor thinking that it's my convertor (kinda unlikely as it's new) I tried throttling back thinking that it was sucking too much fuel. *In this instance it takes longer for the tractor to lug down and eventually die as compared to near full throttle. Temp is just fine at 170 deg. and so it oil pressure. The one thing I noticed is that the governor seems to be surging somewhat until the motor is under near full pull then it evens out. (I replaced all bearings, ect except weights inside the governor). Anyone with ideas or things to test please write away! Thanks Tyler in Missouri
