jdemaris
04-13-2004 19:39:44
Re: 4020 Injector Pump in reply to Mark, 04-13-2004 18:33:34
No, they're referring to turning up the fuel delivery, not the fuel timing advance. Some tractors respond well to it, and some don't. All depends if they were detuned or set high when they left the factory. 4020s are usually good for an extra 5-10 horse. When a pump is apart, the fuel delivery is set with a micrometer. There is a direct relationship between the distance between the rollers that activate the fuel plunger and fuel delivery. Such dimensions are given in inches. There is a leaf spring that is flattened by a screw, the more you tighten the screw, the more it flattens and thus becomes longer. This determines the distance between the rollers and the length of the stroke of the main fuel plungers, and thus the fuel delivery. So, tightening the screw increases fuel delivery, loosening it decreases fuel delivery, and you can access the screw from the outside without taking the pump off the tractor. One note though. If the pump has never been apart before, the factory usually installed "limiting" shims behind the leaf spring so it can't be tightened much past factory specs. Most rebuilders that I know throw the shims in the garbage pail. I used to turn up a lot of John Deeres for the tractor pulls at the county fair before tractor pulling became big business. Turn them up in the morning, and then turn them back down when done. We did however, turn up a lot of new tractors when we sold them. The 50 series tractors responded particularly well, e.g. the 2750 and 2950. Some of the older tractors did too, especially the 2520, 3020, and 4020.
