Old JD 2 1/2 RC Cylinder question
John
04-13-2004 18:20:45
I am restoring an old JD 2 1/2 RC Hydraulic cylinder and have a question about the depth control stops (2 rods on the outside of the cylinder). When the depth control stop is extended, it rubs against the cylinder rod. Is that the way they all were or do I have a problem? I was wondering if that is ok or rubbing the chrome cylinder rod will it wear a groove in the chrome cylinder rod? I will be using the cylinder on different equipment and would like to use the stops at different positions. Thanks!!
Mike M
04-14-2004 08:22:36
 Re: Old JD 2 1/2 RC Cylinder question in reply to John, 04-13-2004 18:20:45
I have seen several of those wear the chrome off the middle of the rod but the stops seemed straight. It is a close fit and more than likely rubs sometimes.
David from Kansas
04-13-2004 21:06:06
John,
I've owned and used a few of those old cylnders and from my experience, if the depth control binds on the cylinder rod it is usually because someone has used the cylinder with only one side of the stop pinned, which can happen if one of the pins jumps out. I would say your depth control is slightly bent and yes, it could cause damage to the cylinder rod if it is rubbing with any pressure at all. The other condition would be that your cylinder rod is slightly bent, which can be checked by rotating it. Good luck.
John
04-14-2004 06:14:17
 Re: Re: Old JD 2 1/2 RC Cylinder question in reply to David from Kansas, 04-13-2004 21:06:06
Thanks David!!! On mine the depth control stop just touches the cylinder rod (no pressure on it) if the cylinder is horrizontal.
