720 Fuel Strainer Assembly Install
pa_popper
04-13-2004 16:24:13
I am going to replace the leaking fuel strainer on a 720 diesel, electric start (valve, glass bowl - everything that screws up into the tank). Is there anything that should be added to the threads when I attach to the tank and when I attach the fuel line? I thought I read that you shouldn't add anything to these diesels. Can someone let me know that best way to go about it?
Mike M
04-14-2004 14:41:22
 Re: 720 Fuel Strainer Assembly Install in reply to pa_popper, 04-13-2004 16:24:13
I always put a little hardening permetex on the threads.I like the hardening type because with pipe threads they don't always seem to tighten up where you need them.
