1950 JD mdl M
Chip Jenkins
04-13-2004 14:17:02
I need some help with my 1950 JD mdl M. I can't find info directing me as to what specific fluids to add to the trans., differential, and hydraulic 3pt. lift syst. I figured out the engine oil and the radiator and I do have a reprinted shop manual and a parts manual but they don't tell how/where to add/drain fluids. Can someone help?
Thanx,
Chip
Matt R.
04-13-2004 20:54:06
 Re: 1950 JD mdl M in reply to Chip Jenkins, 04-13-2004 14:17:02
Hi Chip:
According to the M operators manual and looking at my M:
The transmission / differential takes 6.5 quarts of SAE 90W. The filler plug is by your right heel and the drain is below your left foot when sitting on the tractor seat.
The Touch-o-matic hydraulic system takes 3.5 quarts of SAE 10W (same oil as engine in winter). The system is filled by removing the air breather cap that is in front of the seat. The drain plug and the oil level test cock are under the seat above the belt pulley.
Hope this helps.
Matt
