Gas Gauge - 2510
Rusty Scupper
04-13-2004 13:31:39
The gas gauge on my 2510 doesn't work. Is there any testing procedures that I can do on it. I don't know anything about it, ie: if there is a float or sending unit???? thanks
Rusty Scupper
04-14-2004 06:52:32
 Re: Gas Gauge - 2510 in reply to Rusty Scupper, 04-13-2004 13:31:39
Thanks...I will give it a shot tonight.
jdemaris
04-14-2004 05:47:07
If you find that your sending unit is bad, and can't get Deere parts, you might try J.C. Whitney. I needed sending units for my Deere 1010 and 2520. Wound up buying two universal fuel gauge kits from Whitney. The kit is cheap and comes with an adjustable fuel tank sending unit/float and a matching fuel gauge. Think the whole deal is around $30.
Brokenwrench
04-13-2004 16:13:20
Remove the right side screen.About 1/2 way up the gas tank is the sending unit,its about 2" in diameter with a stud and wire hooked to the stud. Remove the wire,and ground it,and check the guage with the key on. If the guage now reads full,the sender is bad. If the guage doesn't respond,it can be the guage itself or the wire going to it or a no power to the guage.If you have to replace the sender,make sure you have the gas level below the sender when you remove it.
