How to Rebuild Seal ?- Sediment Bowl Shut-off Valv
Ken Reese
04-13-2004 07:52:03
This question is about the seal/washer in the shut-off valve of the fuel body/sediment bowl of my '39 "B". The leather (I think they are leather) washer/seal has deteriorated and replacements are no longer available.
What materials are YT folks using to seal up the shaft to stop the gas leaking around the shaft and on to the block?
I bet there are a good number of creative solutions. Any suggestions will be apprectiated.
Ken
River Rat
04-14-2004 02:02:40
 Re: How to Rebuild Seal ?- Sediment Bowl Shut-off in reply to Ken Reese, 04-13-2004 07:52:03
Lead works the best.
Bill
04-13-2004 14:01:35
I use teflon tape rolled into a string and pack as much as I can tighten nut then put more in you can tighten the nut pretty tight and the valve will still turn easy and not leak works for me
ET
04-13-2004 11:35:41
Go to a plumbing store and get ome rope type waterpump shaft packing. The piece I got was about 1/4" diamiter but you can unravel it a couple of strands at a time and wrap it around the shaft on the shut of valve. If you don't get enough on the first time you can just wrap more on. The packing rope looks like it has graphite on it.
Bob
04-13-2004 10:28:58
As silly as this sounds, old-timers sometimes recommend taking a length of cotton string from a mophead, and drawing it through a bar of old-fashioned bar soap. You then wrap the string around the stem, and squeeze it tight with the nut. It usually seals remarkably well.
Mike M
04-13-2004 09:52:32
I just throw those old style fuel bowls away and replace with the newer style that actually shut off with a tapered seat. Those original type with the cross drilled hole will always seap past the insides and not completly shut off. New ones were around $20 at JD.
Jason Z in Mo
04-13-2004 09:21:38
Ken,
Good question! I have fought those leaky bowls and valves on all my old stuff! I have a few Gravely tractors with the small bowls and they are really hard to stop leaking.
I have tried o-rings without any luck.
Great job at the Gathering of the Green. Looking forward for the next one!
Jason
JD-A
04-13-2004 08:19:25
I used leather, the thick skirting leather from saddle scraps, for the brass valve I drilled a half inch hole w/ a brad point bit then roughed out the outside w/ a pocket knife then stood a wood beltsander up in a vise and sanded the taper around the outside to a tight fit in the housing ,tried to saturate the leather w/ grease,assembled. It has not leaked yet. Now the settlin' bowl was different cut a strip w/ beveled edge a v cut on one end and a point cut to match, lengh is important. Note grease this when you test fit mine went together abd would not come apart , but it only leaks when I kill the tractor and leave the valve on. good luck.
