4755 540/1000 RPM PTO
B. Park
04-12-2004 20:05:29
I recently purchased a 4755 that has only a 1000 RPM PTO shaft and the dealer says that is the only way this tractor came. Does anyone know of a way I can convert this to 540 RPM PTO? Thanks, BP
G-MAN
04-13-2004 10:54:35
 Re: 4755 540/1000 RPM PTO in reply to B. Park, 04-12-2004 20:05:29
There is nothing available from Deere to do so, other than installing a big 1000 to 540 adapter and slowing the engine down to provide 540 PTO rpm. What are you running with it? The 4755 has more than enough power to run any normal 540-rpm equipment such as elevators, manure spreaders and so forth at the reduced engine speed, unless you need the engine wide open for ground speed.
