Clutch problems on G
JD-G
04-12-2004 11:12:18
I'm having clutch problems with my G. After I plow with it, I can't even keep my hand on the pulley due to it being too hot. I didn't think this was normal but wasn't sure if it's too loose or too tight. I do get the distinct popping sound and I've got washers behind the castle nuts since my threads are worn out on the studs. What am I doing wrong? Thanks.
JD-G
04-12-2004 12:45:51
 Re: Clutch problems on G in reply to JD-G, 04-12-2004 11:12:18
Thanks for the feedback. I'll try to tighten it some to see if that helps.
Ravgardner
04-12-2004 12:40:59
I agree with Old. It might be slipping just a bit, causing it to heat up. I think plowing is putting it to test. The clutches do heat up when running but not so hot that you burn your hand. I've seen the paint bubble on one it got so hot. Another turned black as if it was burned. Try tightening the castle nuts just one hole. And try the snap of the cluctch. If it engages and disengages, plow some more and see if gets as hot as before. Good luck Guy. Lets know what happens.
Jack
04-12-2004 12:05:02
Make sure the pulley brake is adjusted properly & isn't dragging. This can eb a problem when the mechanicals become worn.
old
04-12-2004 11:49:33
Can't say for sure but sounds like the clutch is slipping a little and getting hot, you probably need to tighten it up some.
