Front spindle threads stripped..........
Rich
01-25-2004 10:34:26
While cleaning and repacking the front wheel bearings on the 520 I found the nut doesn't tighten. I recall some type of special nut ?? that is used in this case. What is this called .....and where can I find one ? Thanks Rich
jCarroll
01-26-2004 09:16:45
 Re: Front spindle threads stripped.......... in reply to Rich, 01-25-2004 10:34:26
I had this problem and solved it in a different way. Instead of the cotter pin, I used a spring pin (heavier duty). then I got a few machine bushings of differnt thicknesses, and by trial and error, put machine bushings between the castle nut and the bearing until it was the correct tightness.
The spring pin keeps the nut from coming loose on the spindle. the machine bushings take up the space between the nut and bearing.
Mike M
01-25-2004 15:30:36
I was told years ago they were called Swager type lock nuts or something like that. I get mine at the local Ford tractor dealer they stock them as ford used them as standard equipment some places.
mike
01-25-2004 19:29:39
 Re: Re: Front spindle threads stripped.......... in reply to DaveH 50, 01-25-2004 12:02:30
We used to get them from JD, try your dealer , if they have a good parts man he can get them.
