60 clutch problems HELP!
J Swanson
04-11-2004 20:12:15
the clutch on my 60 wont engage properly it either slips or when i tighten it up it wont disengage. the facings are new, so are the 3 clutch springs. the splines on the driver look good. the brass fork has been built up and machined to specs. what could be the problem? please help, its almost time to plow the fields. Thank You for any help.
DON
04-12-2004 17:33:44
 Re: 60 clutch problems HELP! in reply to J Swanson, 04-11-2004 20:12:15
SOUNDS LIKE THE CLUTCH OPERATING SLEEVE AND/OR THE DOGS ARE WORN OUT AND BINDING WHEN YOU ENGAGE THE CLUTCH.
Don c
04-12-2004 04:59:16
Does it snap in and does it snap out, if you have it set to snap both ways then your clutch brake needs adjusted. If you are pulling it back hard to try and stop it it is trying to engauge it self again.
colin.c.
04-11-2004 21:27:51
my brother had the same problem with a R.turns out the drive hub on the end of the crank was cracked.from our discussions,i understand that it can be welded with nickel rod.we are actually looking for an uncracked hub.
