60 head resurfacing
Mike
04-11-2004 17:07:19
I will soon be getting a valve job on the old 60, is it worth cutting the head for some more snap for the engine, not looking to gain alot of hp, just freshen the top end, any recommendations? thanks in advance.
John
04-12-2004 11:09:30
 Re: 60 head resurfacing in reply to Mike, 04-11-2004 17:07:19
Depends. Is it a gas or an all-fuel? If it is an all-fuel it would be a total waste of money to mill the head. If it is gas you might cut .050" off and see the cylinder pressure go up 5 pounds, but I doubt you will notice much difference. The compression volume of Deeres is so high about the only way to make much difference is removing a 1/4".
old
04-11-2004 18:35:37
You could go 10 maybe 15 but if you haven't done the bottom end of the engine I wouldn't, because if the bottom is old and you redo the top you may find the bottom will fall out so to speak
