Edison Splitdorf Mag
John, Canada
04-11-2004 15:06:56
Can anybody tell me how to set up and time an Edison splitdorf Mag on a J.D.-D. It runs on 1 cylinder if I take off Mag and turn it half a turn it makes no difference.
Thanks for any help
John
Duane Larson
04-11-2004 15:41:43
 Re: Edison Splitdorf Mag in reply to John, Canada , 04-11-2004 15:06:56
John,
The ES CD spec 0010 magneto does not provide a spark for each impulse click - it only provides a spark for the compression stroke of each cylinder. Wico magnetos, for example, provide a spark for each impulse click - that amounts to providing a spark on the exhaust stroke also. The ES series is click (spark), click (spark), click (nothing), click (nothing), and this cycle repeats itself. So, lay your spark plugs where you can see them spark, connect them to the magneto and rotate your magneto enough times that you can predict when the right hand terminal on the magneto is going to spark, followed by a spark from the left hand terminal. Then put your thumb over the flywheel side cylinder (#1) and determine the compression stroke - you will feel a rush of air as the piston moves forward. When you are at the top of the compression stroke (flywheel will have "LH Impulse" lined up with mark on transmission case), rotate the magneto drive cup such that it will produce a spark at the right hand terminal, put the magneto on the tractor and connect the right hand wire to the flywheel side plug. Then rotate the flywheel 1/2 turn more (bringing #2 piston up on compression) and you should see a spark at the pulley side. As a test, rotating through two more impulse clicks will produce no spark, then you should be back at piston #1 coming up on compression and the magneto ready to fire it. Once you confirm this operation, put the plugs back in the tractor and the magneto should be providing spark to the proper plug.
Kind of a long explanation, but after you understand that 1) you don't get a spark every click, 2) the magneto produces a spark at the right hand terminal, then the left hand terminal, and 3) you must have a spark at #1 (flywheel side) on compression, followed by a spark at #2 (pulley side) on compression, you will get it figured out.
I figure since these magnetos were made during the depression, they conserved everything back then, including sparks.
easydoesit
04-12-2004 08:20:45
 Re: Re: Edison Splitdorf Mag in reply to Duane Larson, 04-11-2004 15:41:43
Excellent explanation Duane. Once I blew all the oil out of my oil bath (backfiring) before I figured it out! easy
