4230 alternator
matt pepp
04-11-2004 13:21:02
just wonderd if anyone knows which way to wire up a delco remey alternator on a 4230 there is a live from the battery and 3 other wires ones live and 2 0thers which go to 3 terminals on the alternator 2 go on side by side and one goes opposite any help would will be appreciated
Bob
04-11-2004 14:16:12
 Re: 4230 alternator in reply to matt pepp, 04-11-2004 13:21:02
I assume you are installing a Delco 12SI or 12SI internally regulated alternator?
In general... Obviously, the large "HOT" wire goes to the insulated output stud of the alternator. The small wire that is "HOT" with the key on or off goes to the terminal on the alternator labelled "2". (This is the battery voltage "sense" connection.}
The small wire that is fed through a resistor in the wiring harness, and is "HOT" only with the the key on goes to the terminal on the alternator labelled #1. (This is the alternator "excite" connection.)
You seem to indicate there is another wire. If this is in fact a 4230, I can't say offhand what that wire would be for. What alternator did it have originally?
matt pepper
04-11-2004 14:42:00
 Re: Re: 4230 alternator in reply to Bob, 04-11-2004 14:16:12
thanks that makes sense there are those numbers i am only restoring the tractor and the other wire has been added by someone else this alternator has been on all the time ive had it, we are in the uk and these tractors are rare here this is the only one ive seen the only other thing is i cant see a resistor thanks matt
Bob
04-11-2004 14:55:47
 Re: Re: Re: 4230 alternator in reply to matt pepper, 04-11-2004 14:42:00
If it is the same as US original, the resistor is in the small brown wire. That wire has a single strand nichrome resistance wire core. Sometimes that wire, being brittle, breaks inside the insulation somewhere back over the engine. Deere's fix for that is to abandon the original wire in the harness, and they have a new resistance wire in a loom that is run from the alternator back to the cab area, and wire tied to the outside of the original harness. Could this be what you are seeing?
