3 pt hitch for a 60
Willy
04-11-2004 05:43:55
I am starting to restore a 1955 model "60" and I have some questions about the 3 pt hitch.
1. what is the difference between the 800 and the 801 hitch?
2. how many different hitches were made for the two cylinder tractors?
3. what hitch should I be looking for to put on my 1955 "60"?
4.how much should I expect to pay ?
5. can someone please email or post a photo of a complete hitch system?
Thanks for any help you can give Willy
Dean VP
04-11-2004 16:58:42
 Re: 3 pt hitch for a 60 in reply to Willy, 04-11-2004 05:43:55
Willy:
I will try to answer your questions. I gave a workshop on 800 series hitches at the recent Gathering of the Green.
1. & 2.) There are three basic versions of the 800 series hitch, the 800, 800A and 801. There are 3 versions of the 800 model, one each of the 800A and 801. Then JD offered an 801 Upgrade kit that could upgrade the 800 and 800A hitches to another version of the 801. So in essence there are 9 different JD authorized versions of the hitches. The differences are too numerous to mention here but I have pictures on a public site where you can compare them. See below:
2.) The 800 Series hitches were first delivered in late 1953 as the 800 version, then in mid 1955 the 800A and then the fall of 1955 the 801 and the 801 upgrade kit. They will fit on the 50, 60, 70 and the late B's A's and G's. However JD did not recommend that these hitches should be used on the late A's and B's. QWith moderation on implements they will work fine on all. 3.) The most desireable collector hitch is the model 801 as it provides the added feature of "Traction - Trol" But finding a complete one and one that is in good shape is next to impossible. An 800A or 800 version are good as well but don't offer the traction-trol feature which makes them simpler and slightly less expensive.
4.) You can expect to pay between $400 for a version that may be in poor shape and missing parts to over $1,000 for a complete hitch that has been restored. Be very careful when looking at hitches for sale to determine how much of them are really there and what condition they are in. Most of the parts are no longer available from JD so the only solution is to get luck and find theparts you might need at a salvage yard. Most are gone already. Some of the parts are being reproduced such as the evener bar, evener bar pin and the chains and clevises. there are 14 different JD Mast Brackets to adapt conventional JD three point hitch implements to an 800 series hitch. The cast P819A Mast bracket being the most used and also are getting very hard to find. However, a simple non-permanent adaptation of the hitch will allow complete three point implement compatibility. Not a big issue at all.
I have at least one each of the three versions of the hitches and im in the process of assembling a 800 and an 801 version of the hitch for sale. $700 or $800 respectively These would be complete and the correct configuration including all original parts except for the chains/clevises and evener bar. These would be available as add-ons in reproduction form for $100 and $50 respectively if you desire. I also sell a multiple page document that describes in detail all the various parts that make up the versions of the 800 series hitches for $20.00.
You can contact me at: [email protected]
See pictures below:
Willy
04-12-2004 04:11:16
 Re: Re: 3 pt hitch for a 60 in reply to Dean VP, 04-11-2004 16:58:42
Dean what is this "Traction- Trol" ? Sounds like a draft control system. maybe?
Dean VP
04-12-2004 08:24:56
 Re: Re: Re: 3 pt hitch for a 60 in reply to Willy, 04-12-2004 04:11:16
Yes, it is a mechanical leverage system that tries to increase traction as the load increases. JD touted a 30 to 40% traction improvement.
bill
04-11-2004 07:26:57
I got a hitch off a 70, dont know if its 800 or 801, its rough shape and been welded almost every where, Im in nebraska, if youll drive to my door we'll throw it in your vehicle, and Ill say Merry Christmas,,,,, ,billy clause
chuckw
04-11-2004 06:09:47
First off JD never called their hitch a 3 point and if you look at any you will see why, it is a modified unit, the true 3 point came out on the 20 series tractors. I can't say much good about the units as they use those swing chains for stabilizers and the center configuration is worthless in my book. I modified a 801 unit made lower stabilizers eliminating the swinging motion and made an upper unit that bolts on the axle housing and also down to the lower unit. I have a photo of the unit and can email. I think you'll have to pay about 500-600 for one of the JD units before modification. My unit worked excellent on a JD50 however the lift on these tractors do not have the capacity of the later 20 series. It used part of the older tractors and some of new technology. Just haven't much good to say of these unit. Chances are if you try to use at heavy lift you'll blow the internator piston gaskets. The 20 series is a totaly redesigned unit.
JohnDeere_John
04-11-2004 14:12:00
 Re: Re: 3 pt hitch for a 60 in reply to chuckw, 04-11-2004 06:09:47
The model 40 was the first John Deere 3pt hitch. Jon
