JD 3020 Steering Problem
CHAPPY
04-10-2004 04:47:21
I have a friend that has a steering problem on his 3020 JD wheel tractor. When started the hyraulic steering wants to turn to the left with pressure. He says it won't turn to the right. Is it possible that something in the fluid control is stuck open or closed?
Thanks
Brokenwrench
04-10-2004 14:06:57
 Re: JD 3020 Steering Problem in reply to CHAPPY, 04-10-2004 04:47:21
It could be as simple as needing to be bled,or the steering valve could need to be resealed and set. Try bleeding it first and see if it straightens up.
John
04-11-2004 09:15:35
 Re: Re: JD 3020 Steering Problem in reply to Brokenwrench, 04-10-2004 14:06:57
What is the procedure to bleed the 3020 hydraulic system? Mine got a gulp of air and the steering has been acting up ever sense.
Thanks
