1010 tramission fluid
chris
04-10-2004 03:17:57
does anyone no how much fluid it holds and how do you sposse to check it i cant find a stick on it do you add the oil from the top under the seat also is the lift oil in the same place as the trainmisssion is thanks so much chris
Loren NC
04-10-2004 14:15:23
 Re: 1010 tramission fluid in reply to chris, 04-10-2004 03:17:57
My manual says that the transmission capacity "with dual PTO" is 16 quarts and "with transmission driven PTO" is 17 quarts. The hydraulic level petcock on mine in behind the seat. My manual says it holds 4.5 quarts.
buickanddeere
04-10-2004 04:54:46
You need the operators, service and parts manuals from Kim at this site or 1-800-522-7448.
Brokenwrench
04-10-2004 04:36:39
The transmission fill plug is at your right heel when you are sitting in the seat. You add 80w-90 gear oil until it comes up to the bottom of the threads. If you have drained it it holds 9 quarts.The round cap under the seat is the hydraulic fill,you can use hyguard or 10w oil,it is full when oil runs out the petcock which is in the front of the hyd.reservoir at the front of the seat,and holds about 5 quarts from empty. You can drain the hydraulics by removing the pipe plug which is between the uprights for the toplink.
