JD 513 rotary cutter problem (help)
J. chipps
04-09-2004 20:56:38
Hi,
Today purchased a "used" JD 513 rotary cutter from a JD dealer for 675.00. It looks to be in excellent shape. Got it home and hooked it up to my 2040.
As soon as I engaged the PTO and let out the clutch, it sheared the shear bolt. (not sure if it had the correct bolt in it or not)
I stuck another bolt in it and tried it again. As soon as I let the clutch out, it sheared again !
I gave up and hooked to my old dull & rusty WOODS, and did some mowing.
Later, trying to figure out what was wrong, I read through the 513 manual and it does state that when starting the cutter to do so very slowly and at very low RPM to prevent premature shearing.
Are the 513's shear bolts really that touchy ! Or am I doing something wrong ?
Also, what advantage does the "slip clutch" drive shaft have over the shear bolt type ? (I read about them in the manual, but it didn't really explain anything)
Can I purchase the slip clutch type drive shaft for mine ? If so how much do they cost ?
I'm having second thoughts now about buying it, but doubt that they will take it back since it was a "used" piece.
I've had the Woods for quite a few years and put it through some "terribly rough" use and never had any problems or any shearing of anything.
I just don't want to be screwing with shear bolts breaking all the time if that's how these 513's are designed.
Any info and advice much apreciated !
Thanks,
J. Chipps
Handsome Jim
04-10-2004 19:24:02
 Re: JD 513 rotary cutter problem (help) in reply to J. chipps, 04-09-2004 20:56:38
I've had the same problem with my 513. I you look at the hole where the shear pin goes through the PTO shaft, you will probably see that the hole is somewhat 'wallered' out meaning that over time, normal wear and tear caused the hole to enlarge where the shear pin is suppose to fit tightly. If thats the case that is your culprit. There is just enough play there that the shaft can move over the gear box shaft and shear the pin. I've had people suggest that I drill a second hole in the PTO shat for the shear pin. Since I use my 513 for what it was intended, mowing heavy grass and weeds and stay away from the stumps and sprouts, I use a grade 8 bolt and have no problems. I'm not saying this is what you shoud do but it's just a suggestion.HJ
ChuckW
04-10-2004 06:04:14
I believe the 513 is a light weight model and probably does not come with the factory slip clutch, however you can add these to your unit. I suspicion gear box problem with your unit as just starting should not sheer the box...believe I would see if I could trade back in with dealer...
J Chipps
04-10-2004 22:24:13
 Re: Re: JD 513 rotary cutter problem (help) in reply to ChuckW, 04-10-2004 06:04:14
Hey, thanks everyone, for all the information.
I called the dealer this morning and told them about the problem. At first they were trying to come up with solutions as to why it would be shearing pins etc.
I just told them that I didn't want the headaches of the shear pin problem and that I'd like to return it for credit toward some other items that I was going to purchase anyway such as new tire chains, oil, filters etc...
They readily agreed, so I took it back. Reading these post and all the information you all gave, helped me tremendously in my desision. (sounds like the only good way to run a 513 is with the slip clutch set-up.
I read a post on another site that said that JD knows about the problem with the premature shear bolt failure on the 513's and has some suggestions as how to remedy it.
One: Is to use a slip clutch driveline.
The other: Is to use a stronger grade shear bolt (they recommend trying a grade 10 (the original is grade 8), but they (JD) also state that extreme care must be taken because when using the stronger grade 10 bolt, that damage might be done to some other part of the driveline or gear box.
So that don't sound like such a great solution !
I'm just glad they let me return it. I guess I'll just stick with my old WOODS M5 for now. It could use some paint and maybe some new blades, but it works like a champ !
Anyway, thanks again.
J. chipps
