Fuel choice with new pistons
NL
04-09-2004 17:40:42
I just put high compression alluminum pistons in my G. I was wondering what fuel I should use. I assume that regular old 87 will be fine, because I thought these pistons were made for farming back in the day (?) But someone told me I'd have to run premium. I was curious what others like me have had the best luck with. Thanks.
chuckw
04-10-2004 12:08:59
 Re: Fuel choice with new pistons in reply to NL, 04-09-2004 17:40:42
bucikanddeere is correct. Regular gas is good enough.
buickanddeere
04-10-2004 05:00:04
87 will be lots even with gasoline pistons in a G. The compression will likely be around 6.5 to 7.0 to 1. Put her on a dyno to set optimum timing and mixture. Mag or distributor? The idea is not max advance but just enough advance to keep from loosing power. The mixture should be set not for absolute max power but lean until it starts lossing a wee bit of power. Idle mixture should be set not for smoothest idle but as lean as possible without missing.
