Diode replacement
louie
04-09-2004 17:39:29
My 1 yr old reman alternator stopped charging.Is it very hard to replaced the diode ? Is that all that would need replaced? thanks
Clooney
04-10-2004 05:45:23
 Re: Diode replacement in reply to louie, 04-09-2004 17:39:29
Louie, I see below you have a Delco 3 wire..
~There is more than one diode in that alternator.. You need to test them all to see what you went wrong.. If the diodes test out OK then you will probably need a new internal regulator or a rebuilt alternator..
~The place the start is to scribe a MARK between both sides of the case half's so you can re assemble it the same...
~Then remove the 4 case screws..
~Then pull the front case off the rear making sure the stator windings stay with the rear case half...
~Then LOOK CLOSELY at how the stator is wired to the diode bridge, how the diode trio is bolted in, what diode bridge screw is the insulated screw, how the big power stud is hooked up & isolated..
~Once you understand what is isolated & what's not & how it all goes back together.. then ..
~Remove the diode trio [that's the little diode device that is about 1/2" wide & about 1" long with 3 looped connectors on one end & one looped connector on the other end]... Once the diode trio is removed, use an ohmmeter & set it on the 1X scale [or use a test light & battery power] & see if that diode trio will only pass power from ALL 3 loops on the 3 loop end to the one loop on the other end but NOT pass power from the 1 loop end to any loops on the 3 looped end.. Also make sure it isn't open from any of teh 3 rings to the one ring end.
~Next, you can test the diode bridge while bolted in but it is much easier to do it correctly if you remove it first.. Once the diode bridge is removed from the rear case, then use a small screw driver & pry the 3 top little connector straps up from the 3 studs on the diode bridge [you need the 6 internal diodes isolated from each other]..Once the 6 diodes are isolated you can use an ohmmeter [or test light & battery] & test each diode to make sure none are open [won't pass power either way] or shorted [will pass power both ways].. Those diodes are tested between the little connector straps & the diode heat sink that the diode is mounted in.. All 6 of those diodes need to only pass power one direction & not both directions.. All 3 diodes on a side need to pass power the same direction..
~Next, test all 3 wire rings attached to the stator..All 3 should show continuity to any of the others but NOT to the metal stator body..
~Also use your ohmmeter & place the leads between the two rotor slip rings. you need to show continuity between the two slip rings but not between either slip ring & the rotor body or shaft..
~OK, what you have learned in the above tests...
1)- if all the diodes pass the above tests then your diodes are all good, & if your rotor & stator are not shorted or open then your problem is probably a failed internal voltage regulator..
2)- if any of the above tests show a failed diode then replace the failed diode trio or diode bridge..
3)-if any of the above tests show a failed rotor or stator then probably just replace the alternator as the rotor or stator will cost more than a rebuilt alternator..
3)- there is no good way to test an internal regulator at home so if the diodes are good & the rotor & stator are not shorted or open then the regulator should be replaced..
~To re-assemble the alternator you will need to push the 3 brushes down in their bores [with the springs under them] then slide a paper clip, or stiff wire through the holes in the brush holder & hole in the rear case,, then once assembled pull the wire out to allow the brushes to extend & contact the rotor..
Most parts are available from you local auto parts store [they will need to know the output amps that's stamped on the alternator's case]....
Any questions just post back or E-Mail..
[email protected]
Dan
04-09-2004 20:47:17
What type of alternator? Internal or external regulator? Lots of things can go wrong in them, can be regulator also. Diodes normally fail if you arc it somewhere. That can also take out regulator. Depending upon the type alternator you can by pass the regulator to see if it charges then. If so the problem is the regulator.
louie
04-10-2004 04:08:56
 Re: Re: Diode replacement in reply to Dan, 04-09-2004 20:47:17
It`s a 3 wire delco with internal reg.I did arc it once .
