Breaker Point Gap?
Tugboat
04-09-2004 17:37:06
What is the point gap for a JD AO all fuel S/N 278782?
Thanks in advance!
Clooney
04-10-2004 05:57:03
 Re: Breaker Point Gap? in reply to Tugboat, 04-09-2004 17:37:06
Tugboat, I see you have a distributor...
~The breaker point gap is .022" if you have a round body {Delco} distributor & .015" if you have a square body {Wico} distributor..
~In either case the gap is set on the highest point [higest lift] of the points cam..
~Also place a drop or two of oil on the cam oiler wick, or use a small amount of distributor cam grease on the cam lobes [don't use both]..
[email protected]
Tugboat
04-11-2004 16:45:05
 Re: Re: Breaker Point Gap? in reply to Clooney , 04-10-2004 05:57:03
Clooney; Thanks, It has a Delco distributor. Tugboat
buickanddeere
04-10-2004 05:02:20
One could consider the use of the Pertronics electronic module and matching coil. Puts an end to points and their troubles.
Duane Larson
04-09-2004 19:45:02
Tugboat,
The point gap is dependent upon the magneto on your tractor. Wico C and XH run 0.015", for example. If you provide the make and model of your magneto we can make sure you have the proper gap for it.
Mark Scholten
04-09-2004 17:52:38
The answer to your question is .021.On the left side of this page, you will see a header of research and info. You can find the info there. Mark
Tugboat
04-09-2004 18:09:03
 Re: Re: Breaker Point Gap? in reply to Mark Scholten, 04-09-2004 17:52:38
Thanks, Mark!
Greengo
04-09-2004 20:10:15
 Re: Re: Re: Breaker Point Gap? in reply to Tugboat, 04-09-2004 18:09:03
when you look at those tune up specs on that page
it does say .021 but if you look to the right in
that same row it says for magneto set point gap
at .015
Mark Scholten
04-11-2004 07:35:18
 Re: Re: Re: Re: Breaker Point Gap? in reply to Greengo, 04-09-2004 20:10:15
I know you had to add your 2 cents to the replys, but maybe I know if he has a mag or a disttributor. Don't confuse people. They want an answer and a correct answer.
Maek
Tugboat
04-10-2004 03:26:48
Thanks guys, but my tractor uses a distributor. I assume that the .021" setting spec assumes a conventional distributor with breaker points and condenser.
Tugboat
Scott
04-10-2004 04:36:08
 Re: Re: Re: Re: Re: Breaker Point Gap? in reply to Tugboat, 04-10-2004 03:26:48
Hey Tugboat, Hoe`s the AO coming along? Email pics if you get time. Scott & Cindy
Tugboat
04-11-2004 16:47:45
 Re: Re: Re: Re: Re: Re: Breaker Point Gap? in reply to Scott, 04-10-2004 04:36:08
Thanks guys! It has a Delco distributor.
