JD 400 hydrolic problem
greg
04-09-2004 10:57:10
I have a JD400 back hoe that the hydrolics dont work. I dont think there is enough flow to the main hydrolic pump. There may be a problem in the transmission pump, but am hoping its a check valve or blockage in the reverser. The reverser works fine and the power steering works- but is sluggish. Any help would be appreciated.
greg
04-12-2004 19:45:33
 Re: JD 400 hydrolic problem in reply to greg, 04-09-2004 10:57:10
The pick up screen was blocked. I cleaned the screen and the hydrolic functions work, but the engine needs to rev in the 2000rpm range and they function very, very, very slow. The fluid never seems to heat up, nor does any fluid flow through the cooler. Any suggestions?? and thank you for all the help before.
greg
Larry
04-10-2004 06:00:04
I've got a 400 loader/backhoe to, saw your post and was curious as to the responses you'd get. I suggest posting you question on the crawler formum on this same site, there is a guy named jdemaris that seems to be an expert on that era of John Deere stuff--I'll bet he'll give you some excellent trouble shooting tips. I personally haven't had much trouble with mine, but I think the guy that posted here gave you excellent suggestions. Good Luck. I'll be curious to see what you found wrong with yours, I'm in the process of changing my fluid and I'm gonna pull that screen and see what it looks like.
Jonathan
04-09-2004 14:07:53
start with the simple (and cheap) things...remove the suction screen and see if it is plugged. Its behind that short hose that connects the horizontal return filter to the trans. case....remove that fitting...the screen will slide out of there....then post your findings...either on here or email me directly if you want. Also remove the transmission filter/ pump relief valve...Its located behind a plug just above the verticle transmission filter..on the right side of the transmission case. You can see part of it if you remove that verticle filter and look up inside there...it will pry out or try pullling it out the side after removing that plug I mentioned. It comes out as an assembly so you can see if there is any debris holding it open.
