4020 injector timing
Mack
04-09-2004 09:22:37
what is the right way to time the diesel fuel injector pump on a 4020 J D (1966)
jdemaris
04-10-2004 14:46:40
 Re: 4020 injector timing in reply to Mack, 04-09-2004 09:22:37
Just adding to what's been posted already. Timing as described in the other posts only sets your "static" or "initial" timing - not the proper timing when the tractor is running. The way to properly check, or set the timing is #1 to do as already decribed, and #2 run the tractor and find out what it's doing under running conditions, and check the advance. The rectangular opening gets a clear-plastic window bolted to it that has degree marks on it. It's a standard Deere tool furnished by Roosamaster. You then run the tractor at specified RPMs, and see if the fuel timing advance is working or adjusted properly. There is a trimmer-screw with a jam nut on it that is used for setting the advance. The advance will affect the tractor's running much more than the static timing; the static timing will have more of an affect on starting. Not much different that checking the ignition timing on a spark-gas engine, and using a timing light to check intial spark timing and advance - be it centrifugal or vacuum. With the Roosamaster, advance responds to RPM and internal fuel pressure. One more note that applies to the static timing. Some tractors, especially with high engine hours, start better with the static timing advanced a bit. It's trial and error, but setting the pump with the lines lined up is not always the best setting. Set it lined up first, and if it starts well, leave it alone and commence to check your advance. If, though, it skips and smokes excessively at start up, try advancing it 1/2 a pump degree at a time and see if you get a positive response.
mac
04-11-2004 09:45:16
 Re: Re: 4020 injector timing in reply to jdemaris, 04-10-2004 14:46:40
thanks for all the info, its been a great help
hope thats all i run into with this old thing.
these old 4020 run good but not forever!
Russ
04-10-2004 08:00:17
Just something to add, I was told to only to turn the engine forward ( direction it runs) when checking timing. If you back it up go well past the marks and then go forward, the backlash in the gearing will make a diference!
G-MAN
04-10-2004 09:55:41
 Re: Re: 4020 injector timing in reply to Russ, 04-10-2004 08:00:17
That's a good point. You can rotate the engine backward if the mark is just past, but you have to make sure you go back far enough that as you're coming forward again, there is enough movement to take all the slop out of the various gear sets. Going back 20 or 30 crankshaft degrees and then forward is probably plenty.
Dan
04-09-2004 20:50:28
When they say line up it means exact, close or a line width distance will cost you horsepower.
G-MAN
04-09-2004 10:38:27
With the crankshaft set at TDC-compression for #1 cylinder, using the timing hole on on the clutch housing at the RH rear of the engine - two small screws hold it in place - line up the TDC mark with the mark in the clutch housing - the timing marks in the injection pump timing window should be lined up - that's the small rectangular cover on the pump held on by two small screws. One is scribed in the housing and one is on the rotor. Make sure you're on TDC COMPRESSION for #1 cylinder, and not exhaust. If you have any doubts, get yourself a manual.
mack
04-10-2004 19:57:05
 Re: Re: 4020 injector timing in reply to G-MAN, 04-09-2004 10:38:27
thanks for all the info. sure is hard sometimes to get info on the week end. sure helped a lot.
