4020 steel hydraulic lines- aftermarket source?
Todd Wiscal
04-08-2004 23:56:05
Ouch! I need a couple of steel hydraulic lines for my 4020. dealer wants my life savings in return. anyone know of an alternate source? thanks!
Gary in TX
04-10-2004 08:30:30
 Re: 4020 steel hydraulic lines- aftermarket source in reply to Todd Wiscal, 04-08-2004 23:56:05
If your not restoring a tractor original, I have used rubber hyd. hoses to replace some on my 4020 I used to have and my 3020 I have now. Another alternative is check around to some of your auto parts places that make brake lines and have one made just like it. Another alternative if its just a hole, have it brazed. Don that on a bunch of lines too, all are still holding!
Jack
04-09-2004 10:39:44
Depending on where they are, you can splice in hydraulic hose, provided you can get someone to weld the proper fittings on your pipe. When I worked at a Deere dealership, old guy down the street was welding the fittings on & customers simply purchased hyd hose of the correct size.
It's not a recommended fix, but certainly cheaper than the alternative for a 'daily driver'
Jason Z in MO
04-09-2004 07:24:16
Check your tractor junk yards. I have bought used lines for my 4020's without problems.
