4320 VS. 4430/4440
CV
04-08-2004 19:25:22
We lookin at gettin a 4430/4440. The 4320 has been a great tractor. We are lookin at buying one privatelt or tradin the 4320 in for it. What do you guys think of the 4430/4440 series?
DON
04-12-2004 18:05:12
 Re: 4320 VS. 4430/4440 in reply to CV, 04-08-2004 19:25:22
CHRIS ,IF THE THREE POINT HITCH IS NOT ADJUSTED PROPERLY THAT TRACTOR WILL DO EVERYTHING BUT PULL THAT PLOW RIGHT , IT WILL SPIN AND REAR AND DO OTHER THINGS. HAVE YOUR DEALER COME OUT AND ADJUST THE VALVES IN THE 3 PT. HYD.VALVE AND ADJUST THE LOAD AND DEPTH, AND CHECK THE WAY YOU HAVE IT BALISTED.MANY TIMES YOU CAN TAKE OFF THE REAR AND ADD TO THE FRONT.
Mark S
04-09-2004 11:10:39
By all means try to find a 4440 but hang on to that 4320. We farmed with both and the old 4320 is still my favorite. After many , many hours we rebuilt and turned up the old 4320 and it's still an awsome tractor today. 140HP on the dyno after rebuild.
We traded a 4430 for a 4440 and found it to be a far better tractor.
CHRIS
04-09-2004 10:00:43
I LIVE IN NORTHEAST TN , OUR LAND RANGES FROM FLAT RIVER BOTTOMS TO SOLID RED CLAY BANKS AND EVERY THING IN BETWEEN. WE JUST BOUGHT A 4440 ABOUT A YEAR A GO. WE ARE GREEN PEOPLE, HAVING A 3010,4020,4230,AND THE 4440. PREVIOUSLY WE OWNED A 2745 MF WITH THE 540 V-8 PERKINS IN IT( CHEAP HP) UNTIL YOU BUY TRANNY PARTS. THE MF NEVER GAVE ANY PROBLEMS BUT THE 24 SP TRANNY, IT WAS SOME WHAT CUMBERSOME, DIDNOT HANDLE VERY WELL IN TIGHT SPOTS, BUT THE MF SHURE WOULD PULL, WE PULL 5-16 " SEMI MONTED PLOWS, 14' HUTCH-MASTER OFFSET DISC WITH EASE. NO PROBLEMS PULLING ANY OF THIS TILLAGE EQIPMENT. SO WE ALWAYS WANTED A 4440, WE SOLD THE 2745 CHEAP(NO RESALE VALUE) AND BOUGHT A 4440. THIS TRACTOR HANDLES REAL WELL IN THE HAY FEILD, BALING HAY WITH A 605 SUPER J VERMEER , WE WHERE VERY PLEASED WITH IT UNTIL WE STARTED SPRING TILLAGE . WE STARTED PLOWING, 4230 HAS 4-16 SEMI MOUNTED PLOWS, B-1 IN THE QUAD TRANNY, 4440 5-16" PLOWS(SAME PLOWS USED WITH THE MF) TO MAKE THE STORY SHORT WE CAME BACK TO THE SHOP, WE CAME BACK TO THE SHOP ADDED 4 JD WHEEL WEIGHTS, 800LBS OF SUITCASE WEIGHTS, AND THE OUTSIDE AXLE MONTED DUAL WHEEL. WE NEVER ADDED NOTHING TO THE 2745. I'M NOT SAYING THE MF IS A BETTER TRACTOR THAN THE DEERE ,IT IS NOT . I LIKE THE 4440 SEVERAL MORE WAYS TO MANY TO LIST, BUT I WAS A LITTLE DISAPOINTED AT THE WAY IT PERFORMED IN THE FIELD. HANDS DOWN THE 2745 WOULD PULL THE SOCKS OF THE 4440. SOME PEOPLE TELL ME THAT THE 2745 IS A BIGGER TRACTOR, MORE IN THE RANGE OF THE 4640. I DONT THINK SO, JUST LOOK AT SALES PAPERS AT THE TIME THIER BOTH RATED WITHIN JUST A FEW HP OF ONE ANOTHER. THE JD DEALER TOLD ME THE SAME THING THIS 4440 WOULD HOLD 160HP ON THE DYNO, I'M NOT SAYING IT WOULDN'T , HP NOT THE PROBLEM, IT IS THE WEIGHT, THE 4440 JUST WANTS TO STAND AND SPIN ON IT'S REAR WHEELS.
G-MAN
04-09-2004 10:43:51
 Re: Re: 4320 VS. 4430/4440 in reply to CHRIS, 04-09-2004 10:00:43
Any tractor is going to want to spin if it isn't ballasted right, particulary when pulling implements that don't transfer a lot of weight to the rear tires of the tractor. Was that a 540-cube V-8 in the MF? That's about 80 cubes more than a 4440, and probably spinning 300-400 rpm faster, if not more. The MF just happened to be set up for what you wanted to do with it, and you had to set up the 4440 to perform like you wanted it to. Nothing unusual about that. Like you said, the MF would pull, but wasn't worth much when the tranny was out.
cannonball
04-11-2004 08:01:51
 Re: Re: Re: 4320 VS. 4430/4440 in reply to G-MAN, 04-09-2004 10:43:51
hotline shows a 4440 at 10,900 lbs..a 2745 at 13,400 about 2500 lbs different ...a 466 and a 539 engines..140 hp for 4440 and 143 for 2745. have nice day may god bless
04-11-2004 08:04:21
 Re: Re: Re: Re: 4320 VS. 4430/4440 in reply to cannonball, 04-11-2004 08:01:51
correction 4440 is 130 hp
buickanddeere
04-09-2004 13:55:52
To continue on G-Man's theme. Until the 4440 is set up with comparable tire make/size/tread/pressure. Proper hitch height,angle(s) and length from rear axle she won't pull. Even well set up 4240 will out pull a 4440 that's wasteing traction and pulling hard because the plough is drafting sideways/crossways or tilted. Are the ploughing depths identical as well?
G-MAN
04-09-2004 07:42:34
I agree with John. The 4430 doesn't even really compare to a 4440, although the 4430 was a good tractor and still is, the 4440 is superior in pretty much every way. And values reflect that. You'll be able to buy a 4430 for considerably less than a 4440 in the same condition.
John Jenkins
04-08-2004 20:32:55
The 4430 and 4440 are fantastic tractors. The 4430 is more comparable to the 4320 if that�s what you are looking for. The 4440 is a different animal. It�s only rated at 6hp more than the 4430 but it is much much stouter than that. Our 4440 puts out somewhere in the neighborhood of 160hp...and it�s got 11,000 original hours on it! They are equally at home in heavy tillage, rowcrop or the hay field. We�ve run a lot of green equipment over the last 40 years and the 4440 is the best tractor they ever made. Good luck!
cv
04-08-2004 20:38:03
 Re: Re: 4320 VS. 4430/4440 in reply to John Jenkins, 04-08-2004 20:32:55
Do u have any turbos or have it "souped" for it to crank out that many hp's?
cannonball
04-09-2004 05:14:38
 Re: Re: Re: 4320 VS. 4430/4440 in reply to cv, 04-08-2004 20:38:03
both 4430 and 4440 has a turbo on it from factory...one is a 404 and the other is a 466 engine...have nice day may god bless
cv
04-08-2004 20:39:07
Clooney....how much horse power did the 4320, 4430 and 4440 have?
John A
04-09-2004 13:29:13
 Re: Re: Re: Re: 4320 VS. 4430/4440 in reply to cv, 04-08-2004 20:39:07
4320 116 pto hp 404 CID turbo
4430 125 pto hp 404 CID turbo
4440 130 pto hp 466 CID turbo
Rodney A Johnson
04-09-2004 06:12:04
I believe the 4320 was around 120hp
If I recall correctly the 30 series sales lit. went something like 4030 - 85hp, 4230 105hp, 4430 125hp, and so on in about 20 hp increments. However, it was quite common for a 4430 to be developing 135 to 140 hp straight from the factory. This resulted in some problems with the rearends. Early 4430s had the same rearend as the 4230 if I remember right. Factory recalls were done to beef up the early 4430s. When buying a 4430, I would try to find out if the rearend had been beefed up (if not don't buy it).
I think the sales lit for the 40 series went something like 4040 - 100hp, 4240 - 120hp, 4440 - 140hp, etc. Again in something like 20 hp increments. I drove a 4440 that had the injection pump turned up so it was putting out 160hp. It handled it well with no problems. My uncle had a 4640 (rated at 160hp) and had the pump turned up to 180hp. Again there seemed to be no problems.
I think it is also "common" knowledge that the 30 series are harder starters than the 40 series. And, I do recall some complaints about the 30 series being a little light, thus were prown to spinning out due to lack of traction. As with the 20 series, one of the improvements with the 40 series was to bulk up the tractors to improve traction.
Pricewise, the 30 series can be had for a lot less and still get a pretty decent tractor. But, if you can afford one, a 40 series in my opinion is better.
MPK
04-08-2004 22:07:58
I had a 4430, rated at 125 and it put out 140 as it came from the factory.
