430t what does t stand for
steveeasttexas
04-08-2004 18:06:52
my 430 has 11.2\10-34 in. tires on adjustable axles, also has tubular adjustable front axle and sets very high is something going on here i dont understand.
JDKIA
04-08-2004 18:44:51
 Re: 430t what does t stand for in reply to steveeasttexas, 04-08-2004 18:06:52
the "T" stands for the type of tractor such as "U" "I" "C" etc. a dubuque collector could better explain the letters. anyway the "T" means it was a row crop verses other models which where utility
here are some pictures to better under stand these pictures are of a MT and M which is the same series but not the same model as yours so they will differ in apearence....
this is a MT take note of the higher ground clearence
third party image
this is an M take note of the lower ground clearence and more "squaty" type third party image
now when the went to the number series the added some letters, so I will let a dubuque collector explain that,
JDKIA
(john doe killed in action)
Mark Scholten
04-09-2004 04:51:37
 Re: Re: 430t what does t stand for in reply to JDKIA, 04-08-2004 18:44:51
I always thought that an MT was a M tricyle. The triple digit tractors with the w, u, s, t, and so on do confuse me to. Maybe there will be a valid answer on here soon.
Mark
buickanddeere
04-09-2004 04:59:28
 Re: Re: Re: 430t what does t stand for in reply to Mark Scholten, 04-09-2004 04:51:37
The T should have stood for "tall" instead of tricycle. They were equiped with 10-34/11.2x34/12.4x34 rear tires. Just about any wide or narrow front end has been found under them. Usually a rollo-matic or an adjustable wide front. Wide front tractors usually have a center pivit casting for the front axle mount that's been busted and welded or on occassion replaced. There's tendency to throw tow chains around what ever is handiest (front axle) rather than what is strongest( drawbar/frame).
Wayne in Tn.
04-09-2004 06:44:38
 Re: Re: Re: Re: 430t what does t stand for in reply to buickanddeere, 04-09-2004 04:59:28
Steve, in the original parts book, where it shows the pictures of the various models, The (T) is shown as a Tricycle, however there were 5 different front ends available for the (T) Such as a tricycle with 2 wheels, a tricycle with 1 wheel, and 3 different wide front ends. It does get a little confusing, because it seems on the Dubuques, they offered just about any configuration the buyer wanted. Several choices of rear wheel sizes and front ends.
