2520 Hydraulic Pump Coupler
Pete
04-08-2004 15:58:42
The studs that attach the hydraulic pump coupler to the crankshaft broke. I replaced the rubber bushings and studs. When bolting the two aluminum halfs that fit over the bushing together, how far do youn tighten the bolts. Do you tighten the bolts until the two halfs cotact each other? IS their a torque spec?
G-MAN
04-08-2004 16:28:23
 Re: 2520 Hydraulic Pump Coupler in reply to Pete, 04-08-2004 15:58:42
I usually torque them to what the book calls for - 30 lb.-ft. They should also have locknuts installed on the ends of them after they're through the coupler halves. Be sure to hold the cap screw heads while installing the lock nuts, so the screws don't tend to back out. Torque the lock nuts to 30 also. I also usually put a little anti-sieze on the threads to keep the cap screws from getting to "attached" to the aluminum coupler halves.
