Camber
Lee
04-08-2004 09:55:57
I'm at work today and one of the guys asked a question that I was not sure of the answer. I have my Two Cylinder 420V sitting on my desk and he asked the reason for the camber on the front axle. I'm assuming it is to help keep the tractor in the crop row. And the real reason is ..... (I have five real two cylinders at home.)
Phil Munson
04-08-2004 19:32:38
 Re: Camber in reply to Lee , 04-08-2004 09:55:57
Read Clooney and G-man's info carefully; they are two of the very most knowledgeable folks around.
txblu
04-08-2004 13:04:16
What about wheels returning to center after a turn? As I recall, somewhere I ran across and maybe tried non-cambered front ends vs cambered. Seems after the turn, you could release the wheel (while the wheels were turned to the side) and the wheels would return to true track (front to rear) alignment while the non's had to be physically moved back with arm (your arm) pressure.
I have a tractor that had the front axle spindle broken. The spindle normally had a slight outward slope to the bottom. The repairman put the new spindle perpindicular to the axle which made the camber really bad; looked funny. BUT, you could execute a hands off turn with your brake, let off the brake and the tractor would right it'self without using the wheel, if you turned into the side having this excessive camber. I had implement tires on the front which were nice and round and this may have helped the easy turning ane returning. (4010)
txblu
Clooney
04-08-2004 15:29:45
 Re: Re: Camber in reply to txblu, 04-08-2004 13:04:16
txblu, you're thinking of caster [think of a shopping cart] or steering axis inclination, caster tends to center the wheels during vehicle motion.. Steering axis inclination tends to center the wheel to it's lowest point of rotation..
~If there is much tire center off-set to the out side [away from that line drawn through the center of the spindle] it will also want to rotate the tire/wheel/spindle towards the rear when moving forward but both sides will want to do that the same so it is pretty well a wash as one side off-sets the other side..
~Wide front tractors don't tend to run a lot of caster do to making the steering harder to turn [especially if there is a lot of weight on the front end].. Narrow front tractors do tend to run a bit of tire/wheel off set to the rear vs. the steering shaft center line & that in effect is like caster, that tends to make the tractor follow a straight line better & does add some steering returnability.. It doesn't effect the steering effort too much on the narrow front's due to the narrow tire track & little front jacking when the wheels are turned..
[email protected]
txblu
04-09-2004 06:31:25
 Re: Re: Re: Camber in reply to Clooney , 04-08-2004 15:29:45
10-4 on the Caster.
Thanks.
txblu
Mike M
04-08-2004 13:03:00
You must have the largest desk around !!!
txblu
04-08-2004 13:06:44
 Re: Re: Camber in reply to Mike M, 04-08-2004 13:03:00
Humor!
What would the world be like without it. I'd bet he bought it on ebay under the heading"farm tractors". Seems like that is all I can find there for sale is toys.
txblu
Clooney
04-08-2004 11:21:08
Less, G-MAN said it pretty straight.. If you draw a straight line through the center of the steering knuckle with that line running clear to the ground, the closer the center of the tire is to where that line contacts the ground the easier it will steer. There are reasons that can't be done in all applications & even reasons on an automobile that you wouldn't want to..
~There is a second reason that the front wheels are cambered & that is for load carrying ability.. The farther in on the axle that the loaded center of the tire is the more load it can carry without bending the axle & the less bending moment on the axle & wheel bearings.
~Even old horse pulled buggies & wagons had the tops of the wheels tilted out to place the wheel ground contact in farther so they didn�t break axles, it also had the added effect of keeping the wheels on the axles as the wheel tended to work inward & up the axle instead of out & off the axle..
[email protected]
G-MAN
04-08-2004 10:34:14
It makes staying in the row easier, but the main reason is it makes steering much easier. Try turning your wheels around so they're spaced out wide once and compare the steering effort to when they're in the normal position.
