Clutch release bearing lube
txblu
04-08-2004 09:20:57
Does this bearing on a 4010 allow for external greasing or is it perm. lubed?
Thanks in advance,
txblu
37D
04-08-2004 13:57:25
 Re: Clutch release bearing lube in reply to txblu, 04-08-2004 09:20:57
Originally there were two zerks, (one each for the main clutch & one for the pto), accessable by removeing the small cover under & behind the bell housing. I always greased these every time I changed the oil, but I THINK all the replacements are sealed, & aren't regreasable.
txblu
04-09-2004 06:34:49
 Re: Re: Clutch release bearing lube in reply to 37D, 04-08-2004 13:57:25
I'll soon find out. I'll go a looking this sat. I always forget this part when doing a lube job. Had a red tractor and it was easy as they had a 2 screw access plate right under the bearing and upon popping the plate, you were looking right straight up into the zerk.
Thanks,
txblu
G-MAN
04-08-2004 10:32:43
It should be greasable.
txblu
04-08-2004 12:53:47
 Re: Re: Clutch release bearing lube in reply to G-MAN, 04-08-2004 10:32:43
Well, I'll look for an access point.
thanks,
txblu
