35A maincase (long post)
Randy
04-08-2004 07:52:15
I apologize for the long post but have a few questions regarding cleaning up the main case of my 35A.
1. I have removed everything from the main case except for the metal oil filter housing in the crankcase and the middle shaft from the transmission. I can't get the shaft to slide out either side and have removed the snaprings on each end but can't get the bearing assembly off of the right side.
2. I thought I would sandblast the entire case inside and out but didn't know what paint to use on the inside like Deere used in the factory that'd be oil resistant. It appears to be a yellow color but wasn't sure what kind of paint to use here.
3. On the right side of the case behind the reduction gear cover is a thin metal round cover for one side of the differential shaft and wasn't sure how this came out. It appears to be aluminum and if I needed to remove this before sandblasting, how does it fit back in?
Thanks for any help.
Randy
Clooney
04-08-2004 16:38:45
 Re: 35A maincase (long post) in reply to Randy, 04-08-2004 07:52:15
third party image
Randy, the wire brush information below is good info-- This "A" case was done with right angle rotary wire brushes, a pneumatic needle scalar for getting into the small places, & along the raised ribs, & into depressions.. Smaller rotary wire brushes on a die grinder was used for the smaller places..
~Once a preliminary wire brushing & going over it with a needle scalar was done, then a coat of Phosphoric acid was sprayed on & washed off with hot water, then the case was wire brushed again & the needle scalar was used in the nooks & crannies..
~Once the case was cleaned to its present condition it was sprayed with a coat of Vinyl Wash to etch it & act as a substrate to bond the primer, then a coat of DPLF-40 epoxy primer was sprayed on to protect it..
~I have also wanted to paint the insides like the factory did but have been afraid the paint would flake off & plug the oil system.. Once oil soaks into the casting pores I would be afraid no paint would ever stick correctly.. Maybe if a good hot tanking was done first but it would still bother me to paint it without a test run on something first..
[email protected]
Duane Larson
04-08-2004 19:27:36
 Re: Re: 35A maincase (long post) in reply to Clooney , 04-08-2004 16:38:45
Clooney,
Neat looking buggy for holding the case - looks like it allows the case to pivot upside down? I'd appreciate a few words on its use, and maybe a pix to see it better?
Thanks!
Duane Larson
Randy
04-08-2004 14:37:52
Thanks for everyone's comments. I believe I'll just wire brush and not take the chance on sand getting in places where it shouldn't be. I'm still trying to remove the middle shaft in the transmission and have been using a hammer and punch to tap it out but it won't ever push out far enough for me to get my gear puller on the bearing assembly. Any help with this one?
Mike M
04-08-2004 13:11:09
Once you have them stripped down that far I always used a wire wheel in a small angle grinder after a real good hot high pressure wash then followed up with a good scrubbing with stoddard solvent then blow dry. I then have used John Deere buff primer and brushed it on.I think eastwood sells a product called gylptol ? to use on the insides. I have never used it as I just found out about it.
F-I-T
04-08-2004 11:54:05
Randy:
I agree that you should avoid sand. You might want to take it to your local motor shop and have it hot tanked. The hot solution along with the alkaline detergent will remove the residual oils and greases, and probably the old paint as well. If you want to be sure, clean the outside with lye gravy (or use it on the inside as well), and then powerwash it to bare cast iron.
Or, hang it from a tree in a large plastic container and perform an internal and external electrolytic cleaning. Then it would be rust and oil free, and very clean.
Which ever method you choose, use some Phosphoric acid on the bare metal to give it a bit of phosphate coating and also convert any remants of red rust. Then prime as soon as you can.
The forging and casting primer that Deere used is similar to a product that Eastwood sells. It will fill any little pores, and encourage oil to flow back down more quickly. Personally, after 60 years, you don't need it unless you're looking for a factory finish on the inside, too.
Frank
John
04-08-2004 10:06:23
I have to agree, I used a wire brush on mine. Blasting would be ok as long as it is plastic media or walnut shell. Sand will come back to haunt you. I think I had rather have a little water and old nasty oil left in the case than the sand that will remain inspite of your best cleaning methods. If you have it stripped that far maybe there is someone in your area that does media blasting or acid dip?
JR in TX
04-08-2004 09:51:37
I would not sandblast the inside of the case. You will never be able to get all the abrasive out of the cast iron. Actually sandblasting the outside of the case is a little risky. It is impossible to keep sand out critical areas. A wire brush on an angle grinder and then a good coat of Ospho is my preference. Leave the inside as is. Just my opinion.
Mark
04-08-2004 09:42:29
I don't know why you would want to sandblast the inside of the case. But if it were mine I'd just put a woven wire brush on a 4" grinder and remove the exterior paint that way. My 2 cents.
