720 Diesel Standard Bleeding
Spoker
01-25-2004 06:00:23
This is my first 720 Two Cyl. Diesel. I just bought it so I decided to change the fuel filters as it has set up for 6 years. I have just replaced the 1st and the 2nd stage fuel filters and bleed them like the Manual says. I know that the 2nd stage filter did not need to be replaced, but not knowing when the last time it was changed, I changed it any way. Both filters are purged of any air. Now I can not get the air out of the third Bleeded on the side of the engine. I left the fuel on and the bleed plug out for three hr's. I have no fuel comming out of the bleed plug. Is there some other way or trick to get the air out of the Injection Pump? Does the Transfer Pump need to be turning to get the fuel to purge the air? Manual says that the transfer pump does not need to be turning.
Roger
01-25-2004 10:40:58
 Re: 720 Diesel Standard Bleeding in reply to Spoker, 01-25-2004 06:00:23
I must have got lucky, when I opened the bleed screw on the left side of the block, the fuel came out soon after, I don't remember if the tank was full or not, maybe that helped.
Clooney
01-25-2004 06:58:07
Spoker, as a rule you shouldn't change both filters at once on those diesels but that is more of a dirt thing than a bleeding thing..
~Sometimes those fuel rail bleeders are a little hard to get fuel out of if the tractor hasn't been run in a while.. I guess the first thing to try is removing the fuel tank cap [if that gets the fuel moving suspect the tank vent line is plugged with dirt or mud daubers, a common problem]
~If it still won't flow fuel try Gpower's air hose [very low pressure] or I have just stood on a crate & cupped my hands around the fuel tank fill then blown in the tank using my hands as a seal.. Once you get it flowing you should be ok..
~I wouldn't suggest you crank it if at all possible as that could introduce air into the pumps & front injector lines & that could require pulling the valve over to bleed the front injector lines.
~Once you get it bled & started do another short bleed on the fuel rail with it running..
[email protected]
Gpower
01-25-2004 06:15:48
Hey Spoker,
Heard about the new purchase from Jdgnut. I assume that after you open the first stage plug, and the second stage plug, you have closed them back off and opened the third? With this being a gravity fed system, to the transfer pump the flow will still move on to the pump bridge without the transfer pump working. I have put an air hose through the cap on the top of the tank, and a rag to semi-seal around the hose and gave it a LITTLE pressure and started the flow moving well through the system. I am sure someone will get on here and say that is wrong..etc. but it has worked for me several times with no problems. I guess if all else fails you can try that. Let us know.
Gpower
Spoker
01-25-2004 06:56:24
 Re: Re: 720 Diesel Standard Bleeding in reply to Gpower, 01-25-2004 06:15:48
I had thought of useing a small amount of air in the fuel tank but was not sure of how much pressure. Gpower I plan to make it to the Corsicanna show, so I need to get this running again. I will try the air trick, Thanks.
