2 cylinders
mitch
04-08-2004 06:45:11
does anybody know why some of the 2 cylinders will have the true "putt putt putt" while sitting idleing and others will have two short "putt putts" in a row? (kinda sounds like somebodys heart beating) i figured it had something to do with the governor but i've heard alot of them do that
Duane Larson
04-09-2004 06:41:19
 Re: 2 cylinders in reply to mitch, 04-08-2004 06:45:11
Mitch,
If one goes through the exhaust valve timing, one finds the #1 exhaust valve opens, and before it closes #2 exhaust valve opens, and they are both open for about 50 degrees on an A before #1 closes followed by #2 closing. Since the sound we hear is from the exhaust valve/manifold/muffler system, the loudest part of the "putt" is when both exhaust valves are open. I haven't done the timing diagrams for Dubuque engines, but I believe all JD 2 cylinder engines have exhaust valve overlap as described above, and that is why we hear one "putt" rather than two "putt-putt" separated by 180 degrees. However, there are circumstances, as described in other posts here, under which the two "putts" can be distinguished.
I wrote an article on this topic for our Two-Cylinder Club newsletter several months ago, and it is an interesting exercise to follow the valve operation. In a recent issue of Green Magazine it was questioned whether there was a time when all four valves were closed, and indeed there is - for an A it is from 40 deg - 135 deg after #1 TDC on compression. Of course, one could just remove the valve cover and figure this out also.
Clooney
04-08-2004 11:36:17
Mitch, all the old Deere 2-cylinder engines had the two short "putt putts" in a row.. They all fired with a 180� between the first two putts the there was a 540� coast time between the putts again..
~The reason it's more pronounced on some than others is many: ---first is compression ratio, as the lower compression engines had a softer sound,, engine idle RPM was also a big factor as the higher they idled the closer together the two puts were so they sounded like one,, ignition timing had an effect on the sound,, as mentioned below carburetor type & number of throats made a difference due more complete R/H cylinder filling at idle,, exhaust manifold type & length made a difference in the sound,, muffler type [or the lack there of] had an effect on the sound,, mag/distributor type & mounting made a difference due to some sparking on both the compression & exhaust stroke so in some cases a pop came out of an open exhaust valve due to spark on the exhaust stroke, others only sparked on compression,, engine load at idle also had a big effect & as noted below most sounded about the same while working.. Well, the Dubuque�s & diesels sounded different but most of the others sounded similar..
[email protected]
G-MAN
04-08-2004 15:46:43
 Re: Re: 2 cylinders in reply to Clooney, 04-08-2004 11:36:17
Clooney, are you of the school of thought that you're actually hearing both cylinders firing individually, or the school that thinks you're hearing both cylinders firing in rapid succession as one "pop"? I tend to agree with the latter theory, as I've seen the math on how quickly the two firings happen together, and it seems about impossible that the human ear could distinguish between firings at anything approaching a normal speed for these engines.
Clooney
04-08-2004 16:08:52
 Re: Re: Re: 2 cylinders in reply to G-MAN, 04-08-2004 15:46:43
G-MAN, the way my hearing is I'm lucky if I can hear them run.. If you pull the exhaust pipe off the manifold you can definitely hear the separate crack/crack at idle.. With the exhaust system on, then it's harder to hear one from the other as they merge into one & kind of blend together..
[email protected]
Chris
04-08-2004 10:42:45
Different models sound different. The old tractors like the A's and B's only have a "1 barrel carb" so to speak. The 60's and up had the "2 barrels". The one barrels would deliver enough fuel to one cylinder at idle and the other would usually starve. When the governor kicked in the fuel would be greater so it would supply both cylinders. That is where you get the odd putts until you load it down. The 60's and up had the different carb that would deliver enough fuel at idle to fire both cylinders. The 30 series has the most even putts at idle and the unstyled A's and B's and even some of the styled tractors have an uneven putt at idle but I like the sound of those too. They all sound about the same when you load them down. The only difference is the size of the cylinder. A 50 for example would sound much weaker than a 730. The D has yet another sound unique to itself. I believe it is timed different though. Hope we answered your question. Have a nice day.
jb
04-08-2004 10:26:52
I don't know think you can actually hear the two invidual "putts" on the horizontal models(A's B's 60's 720's etc.). Since they fire one right after the other you hear one big "putt". On the vertical models(L's MT's 40's etc) you do actually hear the individual "putts". Hope that makes a little sense.
CPeter
04-08-2004 16:41:59
 Re: Re: 2 cylinders in reply to jb, 04-08-2004 10:26:52
The Dubuques fire just like the horizontal 2 cylinder tractors, 180�apart and then 540� so the difference in sound is due to exhaust manifold and muffler difference, not the fireing order.
CPeter
buickanddeere
04-08-2004 09:20:53
Which models? There are several distinct two cylinder sounds depending on the models/fuel type.
