70 D Engine
KHE 70
04-07-2004 15:17:24
I have noticed on the exhaust pipe some type of black fluid leaking down the outside of the pipe. It is not much, but it is difficult to tell if it is fuel, oil, or water. The engine runs strong and does not smoke. The oil level has been consistent. The oil pressure was around 45 to 50 psi but we have adjusted it down to 25 psi as the book says. I have not run the tractor since then, does anyone have any thoughts.
Thanks KHE 70
Bob
04-07-2004 15:25:00
 Re: 70 D Engine in reply to KHE 70, 04-07-2004 15:17:24
It's called "wet stacking", a mixture of unburned diesel, moisture as a byproduct of combustion, carbon, unburned oil, etc., form the engine operating tool cool.
Work the old girl a little and bring the engine temperature up to 180 or 190, and that most likely will be the end of the slobber.
