620 SPARK PLUGS
SMOKEY
04-07-2004 14:01:46
DOES ANYONE MAKE SPARK PLUGS FOR A 620 BESIDES CHAMPION (FOULMASTER)?
buickanddeere
04-08-2004 09:25:44
 Re: 620 SPARK PLUGS in reply to SMOKEY, 04-07-2004 14:01:46
Auto-lite 3077 is a hot non resitor plug. What tasks does the tractor perform and what is the coolant temp?
Hillbilly In Vegas
04-07-2004 19:11:19
I had a similar problem with my 620 gas about seven years ago. I converted the distributor to electronic ignition and installed a 55,000 volt coil and haven't fouled a plug yet. I run the Champion D23 plug.
John 51
04-07-2004 18:09:53
AC 88L will work but I've been using Autolites. I'll have to look up the #. If fouling is your problem I don't think switching brands will help. Use a hotter plug! There's been a lot of stuff posted here on proper heat range and the possibility of using double crush washers. Do a search. I believe Clooney, John T and Duane Larson have all replied to this issue numerous times.
