Unstyled B tire size
Bguy
04-07-2004 13:15:50
I have 2 35 B's and I just noticed that they have different size tires on them. The first one has 9.5X36s on the rear and 4X15s on the front. The second one has 10X36s on the rear and 5X15s on the front. Both have the same size and style wheels front and rear. The rear wheels are 6 inches between the beads. I know the number/measuring system for tires has changed but which is closest to original? What size did they come from the factory with?
john
04-08-2004 08:37:51
 Re: Unstyled B tire size in reply to Bguy, 04-07-2004 13:15:50
I put 11.2 x 36 titans on mine and they look good. I would think 9.5 would look VERY small and 12.4 would bulge bad.
Bguy
04-08-2004 09:05:41
 Re: Re: Unstyled B tire size in reply to john, 04-08-2004 08:37:51
third party image
John, They are a little on the small side but to tell you the truth I didn't think anything about it untill I set these two tractors side by side. As you can see in the picture the 9.5 X 36's look OK but I think the next size looks better.
John
04-08-2004 10:11:52
 Re: Re: Re: Unstyled B tire size in reply to Bguy, 04-08-2004 09:05:41
Your tractor looks very nice. Always like to see round spokes on the A's and B's. Does it start good? I see it is running in the pic. Purchased a new mag for ours and it now starts first cylinder up most every time no matter how long it has sat. Unless you choked it down, in that case it is moody. Haven't figured out what it is lookin for or how to hold my mouth. The 11.2's look fit right, but by todays standards are still too small.
Bguy
04-08-2004 10:31:19
 Re: Re: Re: Re: Unstyled B tire size in reply to John, 04-08-2004 10:11:52
John, Yea, it starts great. They all seem to have their own little start procedure (3/4 choke & full throttle, 1/4 choke & half throttle, etc)but it almost always starts first or second spin unless somebody's watching :). Both of mine seem to like 4/5's choke and full throttle on a cold start and 1/3 choke & half throttle on a warm start. I usually have to try different settings until I find the sweet spot.
Duane Larson
04-07-2004 18:05:34
Bguy,
If they came on rubber, they would have had 6.00Sx36" rims on round spoke F&H HC177 wheels. The rears would have had 9.00x36" "conventional" tires. With introduction of wide-base tires and rims in 1938-39, the normal recommendation was to replace the 9.00x36 tire with an 11-36 wide-base tire, which changed in 1957 to a 12.4x36" wide-base tire simply due to a difference in where the measurements were taken. That being said, restorer's often think the 12.4 is too wide for a 6" rim and don't like the rounded look. One often sees 9.5x36 tires on the spoke wheels, but that is about as narrow as one should go. The best bet is to go to some shows, look around, and see what tires look best to you. There is no "right answer" to what wide-base tire is best as the rim was designed for conventional tires, which are no longer available.
The front tires on a B were 5.00x15 (they never went to a wide-base front tire).
Dr.EVIL
04-08-2004 08:29:44
 Re: Re: Unstyled B tire size in reply to Duane Larson, 04-07-2004 18:05:34
Dad bought a Styled either late '39 or real early '40 B, had the 4-speed, and little cast Fenders on the brake drums.... It had Factory fitted 9 X 38 Good Years on 9-bolt steel disc wheels. When We replaced the tires the tubes were date coded late summer 1939. Tires were pretty weather checked. Was That tire combination popular?
Duane Larson
04-08-2004 15:16:04
 Re: Re: Re: Unstyled B tire size in reply to Dr.EVIL, 04-08-2004 08:29:44
Dr. Evil,
Yes, pressed steel wheels were first used on B81793, and had JD1250 stamped into the wheel. The rim was a 7Wx38, and used either 8x38 or 9x38 tires. About 2/13/40 JD went to the JD1249R pressed steel wheel for the 9x38 tires. Can you read the number stamped into the wheels? It should be one of the two above.
Dr.EVIL
04-09-2004 05:55:32
 Re: Re: Re: Re: Unstyled B tire size in reply to Duane Larson, 04-08-2004 15:16:04
Sorry - Tractor was sold at Dad's auction back in Dec. 1972. I mounted better newer 10 X 38 tires on the wheels since the old 9 X 38's had huge breaks in the casings. Repainted it the week or so before I left for college in the fall of '72. I remember Dad paid $90 for the tractor in about 1970 and it sold for $125 at the sale. Armstrong start, no lights, hyd. etc. Ran really well as long as We didn't need it for anything. If We put it on the water wagon to haul water to the hogs every day it wouldn't start and We'd have to either pull start it or hook something else to the WW. I think the mag had problems.
Bguy
04-07-2004 18:26:00
Duane, Yes, these are F&H HC177's on the rear. The 10X36's look better to me as the 9.5X36's look a little skimpy and the rim of the wheel sticks out more. Thanks for the response.
Duane Larson
04-07-2004 18:58:07
 Re: Re: Re: Unstyled B tire size in reply to Bguy, 04-07-2004 18:26:00
Bguy,
No problem, glad to help. Some tire manufacturers use tire beads which fit over the wide-base rim lip and they don't look as good (in my book) as the older style beads. B.F.Goodrich still uses the old style beads, but make a 9.5 and 13.6x36 tire, not 11.2. Check with www.millertire.com, Ed can likely suggest the best looking old style tire.
