4020 engine oil and break in ?
Ray
04-07-2004 11:59:37
I just purchased a 1969 4020D. the engine has 25hours on a rebuild. What type/grade of engine oil would you guys recommend? Also, is there anything special that I should know about since it is so new regarding breaking it in? I'm not real familiar with diesel engines.
Thanks alot.
Ray
JD 4020 3020
04-07-2004 16:29:42
 Re: 4020 engine oil and break in ? in reply to Ray, 04-07-2004 11:59:37
On oil I would use the breaking oil, then go back to the regular JD oil. The biggest mistake people make is to take it too easy on the tractor. After the origional break in on the dyno, you should run it hard for a while to break it in. The best thing for it is some heavy tillage, running a chopper, or a silo blower. And when doing this don't take it easy on it!
G-MAN
04-07-2004 13:29:32
It should be filled with JD Break-In oil. We run it for 100 hours, change it and run it another 100 hours. Putting in high-quality diesel oil such as Shell Rotella, JD Plus-50, Mobile Delvac etc, and idling around is pretty much a guarantee that you'll glaze the liners and end up with oil consumption and low compression issues, due to insufficient ring/cylinder wall break-in. I'd contact whoever built the engine, find out what they put in it, and if it isn't Break-In oil, drain it and put it in. And DON'T go easy on it. After 20 or 30 minutes of dyno loading at varying loads below rated horsepower, we pull our new overhauls a minimum of 5 to 6 hours at rated horsepower. I overhauled a 4760 this winter, and the DTAC (Deere Technical Support) instructions for the updated overhaul kit recommend pulling the engine down to 1300 rpm for two minutes at the end of the break-in period on the dyno, as it takes heat and pressure to seat in rings, so don't be scared to lean on it a little bit. DO make sure the engine is fully warm before being heavily loaded, and allowed to cool for several minutes before shutdown.
