2010 Front end
doorguy
04-07-2004 08:01:38
Will any other front end (narrow or wide) fit a JD 2010? A friend has one with a narrow front that has one spindle broken off. Thanks, doorguy
Chris
04-08-2004 20:35:40
 Re: 2010 Front end in reply to doorguy, 04-07-2004 08:01:38
You can bolt a single front wheel, dual narrow front wheels, or a roll-o-matic dual narrow front to it using the same mounting holes as it is using now. The roll-o-matic for the 2010 is different than the ones on 2cyl's though. You can bolt a wide front to it but you have to have the wide front mounting plate and I think you have to change the steering alittle. Not sure on the steering. You can bolt one of the three first mentioned arrangments to it though with no trouble. Hope I helped a little.
doorguy
04-12-2004 19:45:49
 Re: Re: 2010 Front end in reply to Chris, 04-08-2004 20:35:40
Thanks for the reply. I was looking at a 420 front end and it looked the same, but I didn't look at the bolt pattern. Oh well, guess I'll keep looking. doorguy
Chris
04-13-2004 07:23:57
 Re: Re: Re: 2010 Front end in reply to doorguy, 04-12-2004 19:45:49
I don't know where you are located but there are alot of tractor bone yards still around here in the mid-west. You may try some of those or may have better luck posting a want ad on this site. It has worked for me many times, even on hard to find parts. If you need some names to parts places just let me know and I can help. Good Luck.
