JD 3010 Brakes
Darrell
04-06-2004 21:31:11
Just purchased but have not taken delivery on a 3010 gas. The seller advised that the brakes were hydraulic and if you were on a hill
with the tractor turned off the brakes would not work and you would roll. Is this true?
John
04-07-2004 10:10:50
 Re: JD 3010 Brakes in reply to Darrell, 04-06-2004 21:31:11
If the accumulator still works, which it probably don't, you will have enough brake assist left for one or two applications of the brakes with the engine off. Otherwise, mash real hard. The brakes will still work, just be like your power brake vehicle with the engine dead. Better than no brakes but not much better. Park only works if you are parked. If the tractor is moving around 2mph or faster the tranny will not drop into park and you will go for a free ride. What ever happened to those "E" tickets anyway?
WTW
04-07-2004 10:58:07
 Re: Re: JD 3010 Brakes in reply to John, 04-07-2004 10:10:50
John, None of the 10 or early 20 series tractors (before 1969) had brake accumulators on them. Your manual hydaurlic braking features is all you had if the engine died or hydraulic system failed. DW
Bob
04-06-2004 23:22:43
Yes, this is true. The brakes are operated by the main hydraulic system, with oil from the hydraulic reservoir (the transmission and rear end housings of the tractor).
There is NO parking latch on the brake pedals.
There is, however, a "PARK" position on the gear shift quadrant, which mechanically locks up the transmission much like the "PARK" position in a car automatic transmission.
Bob
04-06-2004 23:26:26
 Re: Re: JD 3010 Brakes in reply to Bob, 04-06-2004 23:22:43
P.S....
Upon re-reading your post, I'll add that the brake valves are supposed to go into manual mode when the hydraulic system is shut off. You should have at least some braking with HEAVY foot pressure on the pedals, if that was your question, but as I stated before, there is no way to latch the pedals in that position. That's what "PARK" is for.
