4020 Start-Safety Switch
louie
04-06-2004 18:10:17
Where is the start-safety switch located on a 1968 4020 serial#185xxx diesel? Synchro. Thanks
Wayne
04-07-2004 05:52:41
 Re: 4020 Start-Safety Switch in reply to louie, 04-06-2004 18:10:17
That switch you are looking for is located on the RIGHT hand side. Set on the seat and with both feet on the platform, it is located just about under you're RIGHT heel on the transmission case.
Joe P.
04-07-2004 04:57:19
On my 3020 the swithch is on the left side of the tranny below the lip of the operator's platform. It is the ony thing there with 2 small wires coming out of it. But as I reflect, I think that is the clutch depress safety switch. Seems to me I remember the neutral safety switch being in the same place on the right side of the tranny. One of mine was bad a while back; turned out all that was wrong was the wires in the conector had gotten loose and full of grime from hours of tractor use and were not making good contact with the switch itself. I cleaned them off, bent the conector ends to get good contact with the switch leads, plugged it back in and it is working great.
Bob
04-07-2004 07:13:34
 Re: Re: 4020 Start-Safety Switch in reply to Joe P., 04-07-2004 04:57:19
Powershifts have a clutch depress switch, as well as the switch on the RH side, near the shifter connections at the tranny.
redrock
04-06-2004 21:20:33
The nuetral safety switch for a syncro-range is located under the cowl on the rh side front part of the shifter quadrant. Take the wraparound cowl off and standing on the rh side looking at the shifter mechanism you should be able to see it.
Bob
04-06-2004 23:39:19
 Re: Re: 4020 Start-Safety Switch in reply to redrock, 04-06-2004 21:20:33
Redrock,
I know the 4010's were as you describe. I thought some or all the 4020's were as I described, or was it a serial number thing, or a Deere changeover?
I just now went to JDPARTS, and all they show for the 4020 is the neutral start switch on the side of the transmission, synchro or power shift.
For the 4010's the switch is as you describe, under the cowling.
Does anyone know for sure if any of the 4020's were built with the switch under the cowl?
Jason Z
04-07-2004 10:09:25
 Re: Re: Re: 4020 Start-Safety Switch in reply to Bob, 04-06-2004 23:39:19
I have a couple of pre 194xxx 4020's both diesel syncro range transmissions. The neutral safety switch is located as discribed previously. RH side of transmission case directly under your right foot when seated. Also as stated the switch is hex headed with two electrical terminals.
I had trouble with one. The switch was fine but needed to be adjusted. At the same time I adjusted the shift linkages which made a huge improvement in shifting. Not to mention correcting the neutral start problem.
All of this is covered in the service manual. Don't leave home with out it... :)
Jason
Bob
04-06-2004 18:49:46
I'm suffering from CRS at the moment, but it is a hex-headed plug screwed into the transmission case, either on the LH side, on the side of the transmission near the shift levers, or under the operator's platform. Two yellow wires break out of the wiring harness within 6 inches of the starter solenoid. Follow them to back to the neutral start switch.
