430 john deere
steve east texa
04-06-2004 17:43:27
i have a 430 with 28 in. rear wheels and it needs some work, are there parts available, or is it worth fooling with. she needs a steering tower , also a block, and a gear in the tranny. thanks
Dan
04-06-2004 22:23:07
 Re: 430 john deere in reply to steve east texas, 04-06-2004 17:43:27
I have a 430 and would do most anything to keep it running. Luckly I haven't had to do a lot to it. I would think you could find parts in salvage yards as I believe the 420 parts would also fit and probably some 40 parts. They are a great little tractor and very economical to run.
Wayne in Tn.
04-06-2004 18:04:04
Steve, in my opinion, any 430 is worth saving. Most any part you need is available, either from Deere, aftermarket or used. You may not need the whole steering pedastle, probably could be repaired with new bearings, bushings, ect. As to the block and trans. gears, there are several used dealers that can help you out.
steve east texas
04-06-2004 18:12:22
 Re: Re: 430 john deere in reply to Wayne in Tn., 04-06-2004 18:04:04
thanks wayne but the lower part of the housing is busted , the one that attaches the front end to the tractor
buickanddeere
04-07-2004 14:00:20
 Re: Re: Re: 430 john deere in reply to steve east texas, 04-06-2004 18:12:22
No problem, replacement front axles are sold by Stiener in Michigan and Denegler(spelling?). Sound slike someone ina hurry with limited understanding of physics threw a chain around the front axle and gave her a yank. There are a bunch of commom parts right from the 40 to the 1010 up to serial number 42,000. Mostly from 420/430's after serial number 125,001 to 1010's prior to serial number 31,000.
steve east texas
04-07-2004 20:16:20
 Re: Re: Re: Re: 430 john deere in reply to buickanddeere, 04-07-2004 14:00:20
the axles are fine its the housing which is also the pivot point that is busted thanks for the info
buickanddeere
04-08-2004 12:54:01
 Re: Re: Re: Re: Re: 430 john deere in reply to steve east texas, 04-07-2004 20:16:20
Sorry I wasn't very clear, the "C" channel shaped center casting is what I was thinking of. That's the reproduction part.
