4020 LP Backfire
Dan Bartels
04-06-2004 15:57:47
Have problem with 4020lp backfire ocasionally under load. This started after tuneup -points cond.-plugs. Put in electronic ignition and cured for a while but now is back .put in new switch /coil. no luck still there. Could dist. be so worn out that electonic is not working correct.Always starts good and runs ok at lower RPMS (under 1800) comp. check is even on all the cylinders. Any ideas . Sping is here and need to get in the field .THanks .
scottAR
04-08-2004 19:45:09
 Re: 4020 LP Backfire in reply to Dan Bartels, 04-06-2004 15:57:47
I would say it's running too lean. Put the main load mixture a little more rich and see if that helps. If that doesn't work, put it on a dynometer after dark and see if you can tell if a spark is jumping to the wrong place.
DON
04-07-2004 07:10:28
JUST A THOUGHT DID YOU SET THE PLUGS AT .015? THEY RUN CLOSER GAP THAN GASOLINE. ALSO ARE YOU RUNNING ON LIQUID , NEEDS TO AFTER WARM UP. MAY NOT BE WARM ENOUGH OUTSIDE TEMP TO VAPORISE FUEL IN TANK . ALSO THE ELEC. FUEL SOLENOID COULD BE GOING BAD , USED TO HAVE A LOT OF TROUBLE WITH THEM.
Dan
04-07-2004 12:26:17
 Re: Re: 4020 LP Backfire in reply to DON, 04-07-2004 07:10:28
set the plugs to propane specs. Seems more likely to do it when temp is higher and on liquid. Have flushed traps and screens as recommended in owners manual. Almost wish it would break allthe way so I could find it , but that could be $$$$$. thanks for your input.
DON
04-07-2004 07:22:39
ANOTHER THOUGHT , THE ELEC. FUEL SOLENOID HAS A FUEL STRAINER SCREEN IN IT THAT MIGHT BE PLUGGED AND FREEZING UP UNDER LOAD WITH HIGH FUEL FLOW. DON
Bob F
04-07-2004 04:22:22
Dan
Had a real similar problem on our 4020 LP after we put electronic ignition on it. We tried everything we could think of and the thing was still hard to start and it ran rough after it was started. Finally it would'nt start at all. A mechanic at out local Deere Dealership told me that they have had a few tractors that still had 12 volt generators that after a short time would burn out the Pertronix unit. Apparently the voltage regulators in some generators allow the voltage produced to vary too much. He said that this was what burned out the electronic ignition units. This was not a problem on tractors with alternators and we have some other 2 cylinders with generators that work fine with electronic ignition. Long-story-short, we put points back in our 4020 and it starts great again and runs like it always used to.
Hope this helps
Bob F. in Iowa
Dan
04-07-2004 12:30:31
 Re: Re: 4020 LP Backfire in reply to Bob F, 04-07-2004 04:22:22
It is a Pertronix unit that I put in but it starts and runs good except at say rated pto speed or in that area. Will clear up when load is removed- not always handy when making big rnd bales. Will keep looking//thanks
Mike
04-06-2004 19:09:18
Have you tried a new dist. cap?
dan
04-06-2004 20:01:56
 Re: Re: 4020 LP Backfire in reply to Mike, 04-06-2004 19:09:18
Have tried new cap.Has wire plug wires that Ohm at.10 to.40. This tractor does have powershift / Is ther anything in there that could cause short or electric problem under load/ or could fuel conveertor be damaged from backfire originally??
Any thoughts
