Fanshaft Help Needed, Please!!!
Bill Antique Ac
04-05-2004 18:26:02
We got the 41' B running Sunday after changing all the fluids and generally going over it and checking everything out from sitting for 3 years. We started it and it ran great for about 10 seconds, then the fan flew threw the radiator. Can someone please explain to me or provide me a drawing or picture of how this fan is held in place. It is the rubber torsion type and I don't have a clue what holds this thing on the shaft. The radiator will be fixed tomorrow and we will be ready to put it all back together. Just need to know how the fan goes.
If using my email, please take out the no spam part.
Thanks in advance, Bill
Clooney
04-05-2004 19:06:37
 Re: Fanshaft Help Needed, Please!!! in reply to Bill Antique Acres, 04-05-2004 18:26:02
Bill, did the fan come off the rubber hub, or did the fan complete with splined center hub come off the fan shaft?
~If the fan slid off the rubber hub [the rubber center hub will still be on the fan shaft] then you are stuck finding a complete GOOD? rubber centered fan, or replacing the entire fan assembly with the later clutch drive type fan assembly..
~I don't have any decent pictures of the rubber centered fan as most books show the later clutch drive unit..
~Let us know where it came off at & we'll go from there..
[email protected]
Bill Antique Acres
04-05-2004 19:28:26
 Re: Re: Fanshaft Help Needed, Please!!! in reply to Clooney , 04-05-2004 19:06:37
The rubber is still inside the fan. Here are a couple pics to help shed light on it.
I have a feeling I am out of luck.
third party image
third party image
Clooney
04-06-2004 02:35:01
 Re: Re: Re: Fanshaft Help Needed, Please!!! in reply to Bill Antique Acres, 04-05-2004 19:28:26
third party image
Bill, your fan has failed.That rubber inside the fan is supposed to still be bonded to that metal sleeve that's still on the fan shaft.. That metal sleeve needs to be depressed toward the rear then the keepers pulled out, then the sleeve pulled off the front.. You will probably find that sleeve is rusted fast to the fan shaft & won't move easily.. You will probably need a little heat & a punch to move it. That sleeve is also spring loaded to hold it forward against the keepers..
YOU NEED A NEW FAN...
[email protected]
TIM
04-05-2004 19:39:31
I may be able to locate a good replacement for you Bill. I just got one like it for my 35 B 2 weeks ago. I don't think that you can "GLUE" that one back together. Send me an e-mail and I will see what I can do.
Bill Antique Acres
04-05-2004 19:55:17
 Re: Re: Re: Re: Fanshaft Help Needed, Please!!! in reply to TIM, 04-05-2004 19:39:31
You have mail.
TIM
04-05-2004 18:42:23
There are 2 half clips(keepers) that go on the end of the shaft. You have to push the fan down on the shaft past the end of the shaft, put the clips in, and release the fan. It should spring back out to hold them in. If you need a parts breakdown I can e-mail you one.
Mike
04-05-2004 18:37:55
If it's the rubber type,it's shot,the rubber holds it together,there is nothing to do but to change it over to the clutch and spring type
