60 convert to a Wide Front?
Matt
04-05-2004 18:04:09
Hello All,
I have an John Deere 60 that currently has an Roll O matic front end on it. Where I live it is very hilly and I have been told a number of times that I should put a wide front end on it.
I have never had a problem driving with the Narrow front. I do not have power steering. My questions are: 1. Is a WFE more stable?
2. What is a good WFE to get?
3. I will mainly be using this tractor for Haying, Pulling hay wagons, and Snow blowing / plowing in the winter. I may hook it up to a buzz rig once and a while. Is it worth it?
Thanks a lot for the help!
Matt
Russ
04-06-2004 15:50:26
 Re: 60 convert to a Wide Front? in reply to Matt, 04-05-2004 18:04:09
60 or older; Here is a true story. One of our old timer neighbors used to cut, rake and bale hay with a JD B on some pretty tough hillsides in Northwood, NH. They arranged some drop down brackets on the rear axle studs and put a step on platform on the right side. If the rig was gonna pitch over he just stepped off and stood clear of the accident. We believe he was serious.
PeteNY
04-06-2004 15:40:17
Matt, if you have been using your tractor on side hills for quite a while w/o incident, you have what you need to prevent roll overs; COMMON Sense!
All the wide front will do for you is increase your turning radius thus deccrease the handiness! Pete
37D
04-06-2004 12:30:51
Putting on a wide front will only give you a false sense of security, they do absolutly nothing to improve stability on hillsides, as they ,of course pivot, just under the front of the tractor. My advise-set your rear tires in the widest possible position,put several weights on each rear wheel,& drive very slowly & carefully on hillsides, always taking care to not run the lower wheel in any holes,& likewise don't run the upper wheel over any bumps. Slowly & carefully are the bywords here.
buickanddeere
04-06-2004 04:46:20
How wide are the rear wheels set and which axles/wheels does it have? We take rollomatic front row crops into a hilly bush(forest) to haul tree tops out after logging. Handy to step on a wheel brake and get around a tree. Have them all set out so the tires are flush or past the axle ends. Plus creeping around in 1st or 2nd gear reduces the bounces that could start a roll-over.
fixerupper
04-05-2004 20:56:08
I had a round tube wide front from a 60 on my 630 once and I wasn't real pleased with it because it has a wide turning radius, and backing a wagon with it is frustrating to say the least. A Schwartz is more nimble and turns shorter if you don't mind an after-market wide front. You might find one at a salvage yard or maybe a machinery scalper would have one.
