Dubuque question?
Wayne in Tn.
04-05-2004 10:04:16
On a 420, I am showing lots of oil in the top of the radiator. No signs of water in the oil or at the breather. The water seems to be staying where its supposed to, just not the oil. I will be pulling the head soon, and need opinions on what to be looking for: Head gasket? Cracked head? Cracked block? Thanks.....
Larry G
04-05-2004 13:44:27
 Re: Dubuque question? in reply to Wayne in Tn., 04-05-2004 10:04:16
Wayne, I know what you are talking about. I bought a 430W a couple years ago that had oil in the radiator. I drained and flushed, put in new water, turned motor over several times and oil in radiator again. If you leave off the radiator cap does it belch oil out the fill neck? I had the head checked and found nothing wrong however the block had been bored and sleeved for some reason. The only thing we could determine that somehow it was forcing oil out around the sleeve some way. I ended up using a different block and have the old one still on a shelf. Maybe I will use as a boat anchor. I hope you have better luck.
Clooney
04-05-2004 10:56:11
Wayne, there just isn't that many places pressurized oil comes near the water.. I would think the prime candidate would be the rear of the head where the oil goes up to the rocker shaft or a cyl head gasket..
[email protected]
Wayne in Tn.
04-05-2004 11:14:22
 Re: Re: Dubuque question? in reply to Clooney, 04-05-2004 10:56:11
Thanks Clooney, I will look for that, just hope it is not the block.....
