JD 4430 Shift Cable
smurph72
04-05-2004 09:14:09
I posted last week about transmission trouble with this 4430. Thanks for the replies. Using that information, I found the shift cables. One is definitly broken. It's the lowest shift point on the outside of the transmission. I bumped it into position and got the tractor to start. Runs fine, but won't move.
I tried to get the top of the shift quadrant off to see the other end of the cable. Only found 3 bolts along one edge. It wouldn't budge. What else is holding that cover in there?
How hard is it to get that cable replaced if I get the cover removed from the quadrant?
Thanks for ANY information. I spend my time on the red ones and just help on these green ones from time to time.
dcm
G-MAN
04-05-2004 10:40:32
 Re: JD 4430 Shift Cable in reply to smurph72, 04-05-2004 09:14:09
There are another three bolts (I think it's three) that run through the RH fender into the console cover from the outside. Look between the upper part of the tire and the inner fender, and you'll see them there. They can be a pain to get out, and it's not too hard to break the cover if they're really stuck.
smurph72
04-05-2004 12:13:11
 Re: Re: JD 4430 Shift Cable in reply to G-MAN, 04-05-2004 10:40:32
Thanks for the info. I knew I felt something else holding the cover, but didn't look from the outside.
dcm
david val
04-06-2004 01:02:07
 Re: Re: Re: JD 4430 Shift Cable in reply to smurph72, 04-05-2004 12:13:11
there are two bolts on th rear side of the cover and ther is another one on the front of the cover just above the floor.
david
G-MAN
04-06-2004 05:30:02
 Re: Re: Re: Re: JD 4430 Shift Cable in reply to david val, 04-06-2004 01:02:07
I think he's trying to remove the top cover, where the levers go through, not the cowl side cover.
smurph72
04-06-2004 09:31:26
 Re: Re: Re: Re: Re: JD 4430 Shift Cable in reply to G-MAN, 04-06-2004 05:30:02
thanks for the info, I'll probably have to remove both.....
dcm
G-MAN
04-06-2004 13:44:21
 Re: Re: Re: Re: Re: Re: JD 4430 Shift Cable in reply to smurph72, 04-06-2004 09:31:26
Yep, you probably will once you start tying into the cables. If it were mine, I'd go ahead and replace ALL the cables while I was there and fighting it. It would be shame to put it all back together only to have to take it apart again in 5, 50 or even 500 hours.
smurph72
04-06-2004 17:08:33
 Re: Re: Re: Re: Re: Re: Re: JD 4430 Shift Cable in reply to G-MAN, 04-06-2004 13:44:21
Not a bad idea.....I'll post back upon completition. It belongs to my cousin/employer and he's very likely to just call the JD dealer.
dcm
