620 oil question
smokey
04-05-2004 08:02:33
I bought a 620 gas yesturday. I want to change the engine oil right away. What should i use for oil?
CLW
04-05-2004 08:20:54
 Re: 620 oil question in reply to smokey, 04-05-2004 08:02:33
smokey, the book says to run SAE 10W-30 or if you want a single-viscosity oil use SAE 20-20W for temp. above zero. SAE 5W or SAE 5W-20 below zero.
CLW
smokey
04-05-2004 09:10:02
 Re: Re: 620 oil question in reply to CLW, 04-05-2004 08:20:54
Thanks for the reply. I bought this tractor n.f after market 3 pt, no fenders, good original paint, and straight tinwork for $2000. Does this seem abuot right. It does need a clutch adjustment, and a new seat. What options do i have for a seat?
CLW
04-05-2004 09:43:49
 Re: Re: Re: 620 oil question in reply to smokey, 04-05-2004 09:10:02
Sounds like a fair price for the tractor. I have a 630 (same tractor) that I sure like. If you are talking about a seat cushion you can get them at tractor supply stores or at the JD dealer. If you need the battery box or frame rail for the seat there are aftermarket suppliers for them. If you need the box or rail email me and I will send you the name of some companys that you can get them from.
CLW
[email protected]
Craig M
04-05-2004 09:36:49
If it is running good and working ok then you got a good deal. I have spent way more than that working on mine and have not cranked it yet.
