2 Row Planter
Bob
04-05-2004 06:17:52
Got a 2 row planter for sweet corn.
12 tooth gear to 24 tooth gear or 12 tooth to 12 tooth (which plants the most corn)
Thank You
Mark
04-05-2004 08:59:25
 Re: 2 Row Planter in reply to Bob, 04-05-2004 06:17:52
What I have found in my past experieince is that today's varieties of sweet corn are very small shrunken kernals. This means that you may get 3-4 kernals per drop as compared to what the plates were originally setup for - large kernals of field corn. I usually have to thin mine out or plant in wide rows to make sure you get further spacing between plants....there is nothing worse than nubbins for sweet corn....so you might want to investigate the gear you use...you can also run the planter on a driveway to see spacing...just a few thougths...
dad
04-05-2004 07:02:39
The way you asked I would say the 12 to 12 would plant more corn.
If the 12 tooth grear is the driver and the 24 is the driven, the driven shaft would turn half and many times as the driver shaft. Where as the 12 to 12 booth shaft would turn at the same speed.
